Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
I have owned this upright freezer since new. mfg date 06/2002. Manual thaw. Freezer is not staying cold enough to harden Icecream. Just a couple weeks ago, we took it in to a local repair shop. They had it unpluged for 3 days. Plugged it in, for 4 days. had special internal tempuratue gauge. Said ran just fine. Got real cold quick and stayed cold for the 4 days they had it. I got it back home, plugged it in the next day to let oil go back into compressor, ect. put food back in and worked AWESOME!!! Icecream stayed hard. 1 1/2 weeks later, Icecream was soft. I thought to unplug freezer. Two days later Icecream was solid again. GREAT!! I got it fixed....right. week later Ice cream is cold again. I presume the problem is the t-stat. Is that the problem and if so, is the part # to replace 216788100? Where to buy t-stat. shipping to 84660
Thanks
  • Frigidaire Master
  • 3,361 Answers
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Posted on Mar 12, 2009
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Not all the shelves are getting cold
All the shelfs should be getting cold starting at the top and working down. It may have a leak in the system or a restiction not letting the freon flow. It could of had the problem before the defrost. Small enough problem to stay frozen but won't bring back down to temp. Check to see if it's still in a sealed system warranty if so call for service.
Apr 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Small frigidaire with very small freezer completely fill with frost
Most of the smaller freezers are not self de-frosting, Im not certain about the one you have but usually the only way is to unplug them and let them thaw out for a few hours. Make sure to put towels down to absorb the water or you may have a mess.
Jan 07, 2008 | Frigidaire Freezer Refrigeration White...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
1,074 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
