Question about LG Dryers
LG Tromm Electric Dryer dle7177rm won't heat
MNTECH
  • 1543 Answers
SOURCE: LG tromm electric dryer not heating up
Most likely you have a bad electrical connection, resulting in only 120 volts to dryer. (enough to run the 120 volt motor, but not enough to power the 240 volt heating elements) Turn off breaker. Make sure wires on breaker are tight. Make sure nutral wire is tight in breaker box. Take cover off dryer recepticle and check the wires in it to make sure they are all tight. Check that the connections of the cord at the dryer are tight.
Posted on Nov 04, 2008
SOURCE: LG DLE5932W electric dryer has no heat but is running.
Heating element is bad
Posted on May 04, 2009
  • 142 Answers
SOURCE: LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Posted on Sep 28, 2009
cherylogle
SOURCE: lg tromm dryer electric cooling light staying on
I called LG after seeing this light as well and they say it's supposed to stay on and should "blink" at the end of the cycle. I've never remembered this light staying on in all the years of owning this machine but she (LG rep) said it was normal. Otherwise, if you've checked everything and it's not drying clothes, you may need to have your dryer serviced. :(
Posted on Dec 14, 2009
SOURCE: my lg tromm DLG69885 gas dryer is not heating; oth...
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
Posted on Jul 04, 2010
My dryer is an lg tromm dle7177rm. it is 220v. it has ran fine for 3 years but now trips the breaker within 5 min.
If your breakers are old. I'll start by replacing the breaker to the dryer at the box. It is a common failure. Breakers wear out to. Check the power cord for any burnt markings and look at the outlet as well for burnt or discolor contacts. This will overheat as well causing the breaker to exceed the limit and trip it.
Nov 05, 2015 | LG Dryers
Lg tromm electric heater has no heat
check ur heater element, the hi limit and the thermal cut off fuse.
Aug 27, 2014 | LG Tromm Electric Dryer
Tromm dryer model DLE7177RM spinning but no heat nor drying
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | LG Dryers
Does my lg tromm dlg5988w gas dryer have a pilot light that stay on all the time or only when u start it
heatman101
Aug 09, 2011 | LG DLG5988 Gas Dryer
My LG Tromm dlg5988w dryer won't heat. I am trying to reset the heat sensor but can't find it. I have removed the front cover but not sure exactly what I'm looking for.
Make sure you have 240 Volts going to the dryer. The motor runs on 120 Volts, but the element needs 240 Volts. If that checks out, you would need to trace the wiring using the wiring schematic. That could be fun.
Aug 09, 2011 | Dryers
My LG Tromm DLE 5977W will tumble but won't heat
heatman101';
Aug 03, 2011 | LG DLE5977 Electric Dryer
My LG Tromm DLE2532W dryer is not producing any heat
heatman101./,'
May 15, 2011 | LG DLE2532W Electric Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer will not get hot
Tromm LG DLG5988 gas dryer
Heater not turning on Gas light on Cooling light on at the same time Heat Sensor light on
I checked gas it is on and flowing through the pipe up to the dryer
Can't find igniter, reset switch or fuses on the dryer
Jun 01, 2010 | LG DLG5932W Gas Dryer
Dryers Logo
64 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
