Slow cold water fill, now no rinse/spray cycle
The cold water suddenly slowed, pulled it off but couldn't see any issue. Swapped the hoses around, run the machine on "hot" with it attached to the cold water. Now there's no spray or deep rinse cycle. Any ideas please?
  • Washing Mach... Master
  • 3,361 Answers
There is a filter screen inside the cold water valve.
Remove the hose, then take the filter screen out and clean it.
Replace it in the valve.
Problem solved until it stops up again.
Posted on Mar 12, 2009
Why won't my washer finish it's cycle?
First attack is the lid switch- make sure it connects when closed- you can bypass with a jumper until replaced. After that the water inlet valve. If asking for cold rinse the washer will just sit there waiting to fill. confrim cold water at the valve by pulling hoses or if there is cold at other times like warm wash - you can feel it while filling. There may be a blocked in-line filter so check the external hoses and valve too.
May 16, 2014 | Maytag MAT12PD Top Load Washer
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
GW52F Fisher and Paykel Washing Machine Col...GW52F Fisher and Paykel Washing Machine Cold water valve does not seem to be letting any water into the washing machine, so it does not spray rinse or deep...
You are better off swapping the valves over in the machine until you can buy a replacement valve. I've done this for a month or so until I replaced the valve. Works as long as you only use a cold wash and your cold water is not too cold as to make the machine want to add some hot. If it does this then simply press start to clear the fault.
Jan 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold water valve not working
Sounds like either the water valve is bad, or the screen in the valve is clogged. Take the hose (cold) off at the valve and look for the screen to be clogged. If it is not clogged, replace the water inlet valve.
Jan 20, 2010 | Washing Machines
Water on rinse cycle comes in very slow, >1 hr
The rinse cycle is cold water only. Your filter screen on the cold side is stopped up with sediment. Turn off the water. Remove the cold supply hose from the rear of the washer. The screen is located inside the water fill valve. Take a straightened paper clip and fish the screen out. Clean it and replace it. Do not run the machine without the screen it will ruin the valve. Some hoses also have screens. Check your hoses too.
Sep 19, 2009 | Kenmore Washing Machines
Whirlpool washer will not stop at end of cycle
Turn off extra rinse switch or pull wire going to it. If water is slow the water valve may have a restriction in it. Remove hoses and check for blockage in the hose screens.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Feb 22, 2009 | GE WJRR4170E Top Load Washer
Washer won't fill in rinse cycle
REPLACE YOUR WATER INLET VALVE(HOT,COLD WHERE HOSES ARE)IT'S NOT OPENING ALL THE WAY TO LET THE WATER FILL UP FAST,LET ME KNOW HOW YOU DO-MIKE
Oct 19, 2008 | Maytag Washing Machines
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
