Question about Kenmore Dishwashers
Chopper cover Remove chopper cover
  • 125 Answers
SOURCE: Kenmore elite dishwasher
If this is a rounded cover you need to use a flat blade screwdriver. Make sure the screw is out on the lt side, then insert the screwdriver on the rt side where you see the tab/slot. gently press the screwdriver to the rt to pry the cover out. The chopper will come out easily, going back in is tricky. Use a 1/2 inch open end wrench, compress the spring and insert the wrench between the blade and the screen, then put the chopper back in.
Posted on Jan 31, 2008
hotuna
  • 288 Answers
SOURCE: dishwasher leaking from bottom
The leak is coming from the main seal? The chopper thingy on these old machines will not come out without a fight. These impellers have been there a long time and has had lots of hard water and crud to hold them on. Get a screwdriver or a reasonable facsimile and carefully bust it off. Be careful not to damage the shaft. If you pull the whole motor assembly out, replace the rubber gasket too.
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: Removing Chopper Cover
service manual for gu1200 and gu1500
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Posted on Jun 12, 2008
  • 188 Answers
SOURCE: how do i remove cover on food chopper? kenmore 665
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
Posted on Feb 22, 2009
aborcass
  • 2651 Answers
SOURCE: Whirlpool dishwasher chopper blade
you can replac the chopper as a seperate part, but will quickly clog, and destry ohter parts of the unit if removed. dont take this the wrong way but if you have a garbage disposer already rinse the dishes better to avaid further clogging of chopper
Posted on Mar 31, 2009
Whirlpool quiet partner II top rack sprayer doesnt work
The top rack spray arm doesn't work because of low water pressure from the wash motor or it's clogged with debris.
If the top spray arm looks clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
Apr 03, 2009 | Dishwashers
Top tray of Kenmore Quietguard3 dishwasher not cleaning!
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm and lower feed tube to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
Apr 03, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The upper rack doesn't not appear to get all the dishes clean. Why does this happen?
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary (part # 8268383). If the motor gear is broken, replace the sump and motor assembly (part # 8535150). Remove any debris from the sump area in the process.
You don't have to because the door will be open, but if you feel more comfortable shutting off the power to the dishwasher, do so.
Mar 05, 2009 | Whirlpool 24 in. GU3200XTPS Stainless...
Mar 05, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
How do i remove cover on food chopper? kenmore 665 the problem is top shelf dishes not getting clean. looking to clean out bottom area,thanks
Feb 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher not starting
First I would check the chopper it maybe jammed or something blocking it...
1) remove wash arm holding the center and rotate the arm.
2) remove upper wash tube rotate to the right
3) remove screen screws to remove screen
4) pull up accumulator
5) reomve screw on chopper cover...
6) check chopper
7) if chopper clear .. you will need to replace motor
to replace motor
1) remove toe cover
2)remove drain pump
3) remove 3 hold tabs by sliding them out.
4) lift out accumulator base.
5 remove and replace motor.
Oct 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Whirlpool Quiet GU2300XTLS2
Check water level:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Rinse arms not spinning
Could be a a couple different issues.. Not filling with enough water or food chopper brokeen or food chopper filter screen clogged.
Check water level:
Jun 10, 2008 | Dishwashers
Water not spraying hard enough
Check water level:
Sep 30, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Dishwashers Logo
13 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
