Question about Canon MP610 Photo All-In-One Printer
The system says error 5100,
I know yhat a little piece of paper i9s left in the printer. I cannot see it and I do not know how to get it.
  • 4,041 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Www canontechsupport com
Usually an error 5100 code is saying that the ink carriage has problems. Usually something currently is or recently hammed the cartridge carriage. With the machine turned off and the power cord unplugged, open the machine and inspect the inside do you see any stray pieces of paper along the paper's usually route?
There is a way to reset the machine to clear out the error. I would need to know the exact model of your Canon.
for more help visit CBR Tech Solutions
Apr 02, 2014 | Canon Office Equipment & Supplies
I had a paper Jam and know printer error 5100 mesage is coming up, I turned off the printer for 5 min but when I turn it back on it make a turn nois and then a screeching noise then stop.
Sometimes when you get a paper-jam and remove the sheet, there can be little pieces of paper still stuck in the machine. This will cause your printer to do exactly what you are describing. Also remember that when removing a paper jam, use caution and care when removing the paper. To much force can damage the rollers and small gears inside your machine.
I hope this assists you,
Regards,
Nico
Jul 06, 2011 | Canon MX882 All-In-One InkJet Printer
Erreur 5100
Error 5100 is a print head homing error.
Check to see that there is nothing blocking the carriage from moving fully - a torn piece of paper, scrap plastic from an ink cartridge etc...
Also confirm that the ink cartridges are completely and correctly seated.
It would also help to know which model printer you are referring to.
Feb 27, 2011 | Canon Office Equipment & Supplies
I have an error code 5100. It started grabbing the paper wrong and a piece got jammed. I removed it and then it says error 5100. I have turned it off and on a few times and it is still there.
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Error code 5100 displayed with orange alarm and green on off buttons flashing on and off
According to the manual, Error message 5100 indicates: "Movement of the FINE Cartridge Holder is blocked. Open the printer
and make sure there is no little piece of paper or other
object keeping it from moving. Unplug the printer.Then disconnect the printer f
from the computer. Plug it back in and try it again.
Aug 11, 2010 | Canon Office Equipment & Supplies
The printer shows error code 5100 I think it has
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Next try.
Solution 1:
Solution 2:
Good Luck.
May 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Error 5100
Hi There
Next try.
Solution 1:
Solution 2:
Apr 03, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Jul 20, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Error Code 5100
For error 5100 try the following, I know it works on some Canon printers:
Unplug printer, press and hold "resume" button, press "power" button and hold down, release "resume", press "resume", release and press again. Release both buttons and now press "resume" 4 times. Power off. Re-start.
Hope this helps.
Norman
Dec 20, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon MP610 Photo All-In-One Printer Logo
175 people viewed this question
old marine
old marine
