Question about Asrock P4I45GV R5 Motherboard
System become hang when operating sys. is load. and if load then after few day it says boot failure and hdd. detect but not support what is the problem in my system. i already change my hdd. and ram but problem same what i do
    Problem Solver:
  • 10 Answers
Reinstall your os nd install lesser programs on c drive...
Posted on Aug 13, 2009
    Problem Solver:
  • 15 Answers
Make sure you have your hard drive selection on cable select on the back of you hard drive. Also did you change the ribbon cable when you changed hard drives?
Posted on Mar 12, 2009
Power failure,command display (no bootable cd)
It seems that your first boot was on cd or dvd, or may be your hard drive did not detect, to check both of them go to BIOS set up by pressing F2 or Delete on your keyboard to enter set up. When you are in set up mode go to Boot menu (if you can not see boot menu go to advance). In a boot menu select HDD as a first boot and Cd or DVD as a second boot, if you can not find your HDD it means that your HDD did not detect, and you need to replace it with a new one.
Hope it gives you a solution
May 30, 2011 | Computers & Internet
Gateway 4542 gp hung up during reformat. I had sudden hard drive failure but was able to get it to boot after multiple try's. It got the pxe error for realtek Ethernet card because I assume it was looking...
Hello
Sounds as if you have a possible corrupt install of the operating system.
You can try booting from your windows disc and choosing delete existing partition, then format,then reinstall windows.
You will need your hd plugged in for this.
Feb 06, 2011 | Gateway 4542GP Notebook
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
your system either does not detect a bootable disk, or the HDD has failed. Disconnect any floppy disk, USB storage devices connected to the computer and make sure the HDD with an OS installed is the primary boot device. If you get the same error, remove and reconnect the hard drive. If all else fails, try repairing or reinstalling Windows. If nothing works, you may need to get a new HDD.
Aug 25, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
Problems with my inspiron 1501 details below
The problem your having could be the operating system is damange or the hard drive failed. Try to boot from a Windows XP or Vista CD to see if the drive is recognized.
Regards,
Sep 01, 2009 | Dell Inspiron 1501 Notebook
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
Unable to login in my computer
try setting your bios to defaults when you get in that bios screen.make sure to save it and then exit.you may also need to reinstall windows os .vista or xp etc.
Mar 04, 2009 | HP Hewlett Packard Smart Buy- dc5750...
Boot up
check it on bios hdd is detecting or not, if detecting then its the problem of your os, load it again
Nov 01, 2008 | Acer Aspire 5050-3242 Notebook
New operating system wanted
after formating hdd u can install any op sys on ur computer, please put ur op sys cd in drive
after starting computer and boot it with this cd when u start ur computer u will get a massage "press any key to boot from cd"
and install xp from cd also format ur hdd with xp op sys
it will solve ur problum
Jun 02, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Boot Failure
i am assuming you have allowed the bios to detect that there is a different hard drive fitted as it will be looking to boot from an non existent drive. If you have fitted a new HDD with an operating system already on it then you will have to repair windows as its a change in hardware. If you cant get the bios to see the drive then the motherboard has an IDE or Sata connector problem.
Sep 13, 2007 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
56 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
