Question about Dell Inspiron 1525 Notebook
Dell Inspiron will not work on Battery.
My 11 month old Dell Insperon 1525 will not work on battery, it must be attached to the house AC. Looking at the battery check ikon it says "88% available (plugged in, not charging)" and then, below it says "Current power plan: Dell recommended". I am not a techy. HELP
  • 4 more comments
  • Anonymous Apr 10, 2009
    but my battery is stuck in the 75%
  • Anonymous Apr 24, 2009
    Same problem, my laptop is probably about year old now, but the battery doesn't charge. I can only use the computer when plugged in.
  • panrajeev May 07, 2009
    Even I am facing the same problem, my 1525 is also an year old by now.
    suggest the solution.
  • Anonymous May 08, 2009
    0 % (plugged in, not charging)
    has to stay connected to the ac :(
  • j4m1elynn May 14, 2009
    I even bought a brand new battery for my Dell Inspiron 1525 (which is only 14 months old at this point!!!!), and when I installed the new (larger 9 cell battery, as opposed to my original 6 cell battery) the same "plugged in, not charging" thing comes up. BRAND NEW BATTERY, same problem!
  • exbake May 15, 2009
    Thanks everyone. All the people who said it's the battery seem to have been right. I sent the computer, still under warranty, back to Dell and they fixed the "LCD Panel" (whatever that is) and sent me a new battery. The computer seems fine now.
    Thanks again,
    EXBAKE
    Problem Solver:
  • 8 Answers
It's 11 months old, call Dell technical support, they should send you a new AC adapter, most likely it's not the source of the problem, then they will replace the motherboard of your laptop. This is a very common problem with Dell Inspiron 1525, it's not the adapter, not the battery but the motherboard.
Posted on Apr 07, 2009
    Problem Solver:
  • 15 Answers
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Posted on Mar 12, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 77 Answers
That is caused by your laptop motherboard. As the laptop cant understand your battery. Many dell notebook not only inspiron 1525 have this problem.
Advise you reset the bios or take the bios battery out for about 3 minutes then insert into it.
You will get some info this : http://www.laptops-battery.co.uk/blog/dell-ac-power-adapter-type-cannot-be-determined-solution/
Posted on May 15, 2009
  • 34 Answers
Sure, it is under warranty so Dell will help you replace the parts etc.
Posted on Apr 13, 2009
  • 7 Answers
First is to try a known good battery. it could be the battery. if you can still use the laptop with the ac adapter then ac adapter proves to be fine. if a new battery does not fix the issue then problem could now be the motherboard.
Posted on Apr 10, 2009
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 won't charge the battery
in your case frist chack with any technician let him chack your leptop
or try frist other bettry then only go for a new battery
Apr 21, 2010 | Dell Inspiron 1525 Laptop
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Battery won't charge
i recommend you to buy new one.. for dell 1525 .. must better
Jun 08, 2009 | Dell Inspiron 1525 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
AC adapter not recognized
If you don't get any errors when you startup on battery then all you have to do is call Dell. Get work order number and send them the laptop and adapter. They are very fast. I sent a laptop to them last month and I had it back in 3 days! I was surprised.
Dec 04, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
836 people viewed this question
Alun Cox
