Dometic Quick Cool 59516.731G
Water is leaking into the interior roof structure. Is there a drain or how do I correct.
  • 86 Answers
SOURCE: Dometic roof top air-con trouble
1.check wiring of unit.
2.check drain tray.
3.check u band of drain pipe.
Posted on Mar 17, 2008
manhandy
  • 146 Answers
SOURCE: dometic quick cool a/c compressor runs for 1 min
well dose it eventually shut off? most ac unites will run for while after the compressor turn off this is not anything unusual. but is it cooling the RV down? and dose it have Thermostat and is it the right place not hot or cold
Posted on Jul 05, 2009
farfield
  • 462 Answers
SOURCE: My dometic RV rooftop air conditioner is leaking
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Posted on Jul 10, 2009
  • 4 Answers
SOURCE: Dometic Quick Cool compressor freezing and evaporator coil
Could be low. First check air filter, air flow, and evap coil to see if it has restricted airflow. If all seems well, its probably low. The specs will tell you what type and how much refigerant. To access system, you will need a gauge/manifold set, refrigerant, and a piercing or line tap valve for the low pressure side of the system. Of course, first, you need to locate and repair the refrigerant leak.
Posted on Jul 27, 2009
  • 99 Answers
SOURCE: Dometic Quick Cool Duo Therm Model 59516.601 runs
Hi; How old is the unit. Sometimes the condensing coils get clogged and need to be cleaned. Or the compressor is not in operation due to an electrical problem or the compressor is out due to a safety feature called a thermal overload. This protects the compressor from failure to a high heat or pressure situation. Alot of consumers run to the need freon theory before checking a few other things. Take Your time and be carefull .I You do not feel confident in Your trobbleshooting skills call a qualified tech...alpharome416...P.S. If You are going to take on this complex task please remove power before doing anything like removing covers or electrical panels!!!
Posted on Feb 20, 2010
Is it common for a rv rooftop air conditioner to leak water on to the roof? I have a Dometic Duo-Therm unit 579,590,595 series.
All AC units create condensation from the cooling of air (cold/cool air hold less water than warm air), it is worse in areas of humid air like the Midwest for example.
May 12, 2017 | Dometic Heating & Cooling
Water Leak from roof
possible stopped up drain or coil iceing up.
Nov 26, 2013 | Dometic Rooftop RV Air Conditioner
Water pours into my ceiling and out the vents even when on low cool
Have you noticed a reduction in water/condensation running across and off your roof? Most likely have plugged drain holes on upper (roof) unit. You'll have to remove cover and look for blockages at drains for evaporator ( front) which has a drip pan under it.
Oct 04, 2011 | Dometic Rooftop RV Air Conditioner
When my a/c is on it leaks water,right down through the vent.is there some drain holes up on top that may be pluged up.
Yes! There should be a drain tube that dumps the water on to the roof, if the tube is plugged then water builds up in the catch pan and eventually overflows running into the coach. You will need to take the shroud off to see where the water needs to drain, should be on the left side if your facin the front of the trailer while standing on the roof. Might be a leak in the roof but I think the drain is plugged on this one.
If this was helpful a vote with the thumbs up would be appreciated.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
Water leaks from the roof unit
This is condensate (which of course is water) that is coming from your unit. This is very normal ... Is it leaking inside or running across the roof and down the side of your unit? If it is going inside, there is a drain in your roof unit that is clogged. You must clear the clog. Remove the cover and inspect the base. Turn the unit off first.
Sep 19, 2010 | Dometic Rooftop RV Air Conditioner
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
Have a Quick Cool RV roof unit compressor:
Try ( www.dometicusa.com) site and they have dealer locator on there site for wherever you are.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
2.check drain tray.
Feb 16, 2008 | Dometic Rooftop RV Air Conditioner
Coleman RV air conditioner
It is not leaking. that is the condendensation it is pulling out of the air. It is suppose to leak on the roof and off the camper.
Oct 06, 2007 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
