Question about Mackie SWA1501 Subwoofer
Can I replacement the woofer on a swa1501 with any woofer
  • 3 Answers
Yes, with the appropriate replacement driver in size and similar specs regardless of the brand. P-audio drivers worked fine in this unit.
Posted on Dec 03, 2013
Why does it randomly lose power?
Hello, I can not say what the direct cause is,
perhaps some soldering points on the printed circuit bords are loosen due to thermic stress. test: give mechanical ticks on the woofer while he is playing to check this.
Hope you will have succes.
Jun 11, 2015 | Mackie SWA1501 Subwoofer
Nesecito urgente el diagrama electronico del Mackie SWA1501
  • Espero que esto ayude y gracias por usar FixYa
Saludos, Tony
Aug 26, 2011 | Mackie SWA1501 Subwoofer
What is the low frequency driver
Usually the "low frequency driver"is the speaker that is responsible for playing the lower frequencies of the audio. Otherwise is the speaker that is in the subwoofer, or the woofer at the 2-way speakers. Do you came up with a problem with your own subwoofer or you are just asking a question?
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 13, 2010 | Mackie SWA1501 Subwoofer
Any idea why my Mackie swa1501 bass bin has blown 2 speakers in the last 3 months? Bass Drum is the heaviest instrument going through it, but I never let it clip, I also run a fan on it which keeps it...
does your swa1501 get hot just being switched on ?
sounds like your output transistors breaking down or your dc to dc rectifier is shorting this would dumping high voltage to the speaker. I guess your speaker coil is burnt . check Q4,Q5,Q7,Q12.Q14,Q15,Q17 and Q18 these are all mosfet transistors that commonly break down..
Oct 01, 2009 | Mackie SWA1501 Subwoofer
Where is the crossover located in the mackie srs 1500and does the crossover have a fuse.
The Mackie SWA1501 has an active electronic crossover on its main circuit board.
Jul 15, 2009 | Mackie SWA1501 Subwoofer
SWA1501 Sub blows fuses when turned on...
Shorted amp or blown speaker. Other things could also cause it. But there is a short circuit in it.
Mar 08, 2009 | Mackie SWA1501 Subwoofer
I have a pair of mackie srm 450 and one swa 1501 the bass output in one of the 450s has no sound. i hear sound only from the high frequency part of the speaker
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Dec 04, 2008 | Mackie SWA1501 Subwoofer
Problem fith mackie swa1501
Hi There, If you can send a pic to info (delete this bit) at (delete this bit) londonspeakershop.com then I should be able to assist you with getting the replacement part. Best Grant
Nov 23, 2008 | Mackie SWA1501 Subwoofer
Replaceing internal fuse to mackie active sub woofer swa 1501
Hi There, you need to check the 3 fuses that clip onto the main amp board. You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these by pulling out the burnt out fuse and replace with a new fuse and hey presto you should be back up and running. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Also the offer a service of swapping them over for you if you really don't want to do it yourself. Hope this helps. Grant (from www.LondonSpeakerHire.com)
Oct 07, 2008 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
69 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
