Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
How to bleed a clutch on a 1997 chevy 1500
Clutch pedal gose to the floor with clutch master cylinder full
    Scholar:
  • 117 Answers
You may have a bad clutch master or a bad slave cyl. To bleed the system you need to find the bleeder screw under the truck where the slave cyl enters the bell housing. Make sure the master is full of fluid. Note-some reservoirs will have an rubber cup insert inside which will make it look full . If so take it out.
Open the bleeder at the slave cyl and watch as the fluid comes out to see if there is any air. After a while, close the bleeder and pump the clutch pedal to see if it is starting to work. If not, repeat opening the bleeder again etc. If you get a little pedal, then hold the pedal to the floor and have someone open the bleeder. Close the bleeder and repeat until you get a good pedal. If you have no success you may have a bad master that is not producing pressure.
Posted on Nov 02, 2013
2 Suggested Answers
  • 6468 Answers
SOURCE: master cylinder resevour is pumping fluid back up thru lid, i just replaced rear brake line,and tried to bleed the lines. does anyone know what might be problem?
try and bleed out the front brakes to get the preportioning valve to center
Posted on Jun 10, 2012
Why is it a little hard to shift gears?
Lets say 2 things the clutch itself is worn or it's not releasing the clutch enough from the pressure plate.
I suggest a small test
1. Start engine while clutch pedal is releasing the clutch plate hold the brake pedal at the same time and then release the clutch pedal slowly .
How far is the pedal from the floor
You have to be carefull with the bleeding procedure.
You can bring air into the system and result is your problems
Hope it helps
Feb 03, 2018 | Chevrolet Cars & Trucks
How do i bleed the clutch
Make sure clutch master cylinder is full of fluid. Pump clutch pedal several times and hold to floor. Open bleeder screw located on slave cylinder at transmission ( air/fluid will come out ). Close bleed screw and bring clutch pedal back up to to top. repeat this procedure until only fluid comes out of the bleedscrew and the clutch pedal feels good
Jan 05, 2016 | 2005 Ford Fiesta 1.4
Clutch travel to the floor
the brake fluid has drain out of clutch master cylinder fill with brake fluid reservoir is next to the brake master cylinder. pump pedal if spongy then bleed system with a 2 ounce syringe at slave cylinder loosen screw and force fluid to the master this will push all the air out.
Apr 22, 2014 | 2002 Honda Civic
Replaced the clutch master cylinder in 2001 kia sephia but still not working. The fluid wont go to the cylinder even after bleeding what did I miss?
Hi Monique, As you have replaced the master cylinder, what is the condition of the slave cylinder? I wonder how you are bleeding the system. The procedure is as follows. Fill the reservoir and have a friend keep it full as the bleeding procedure is carried out. Pump the clutch pedal all the way to the floor and then release it to the upper end of its travel. do this until you feel pressure in the pedal and with the pedal pressed all the way to the floor have a friend open and then after two seconds close the bleeding nipple while you hold the pedal down. Once the nipple is closed repeat the action and the bleeding procedure. The nipple must only be opened and then closed while you hold the pedal to the floor. Repeat the procedure until the clutch action returns to normal. Regards John
Sep 09, 2012 | 2001 Kia Sephia
Repair master clutch cylinder
Check your fluid level. If it is full, the clutch master cylinder is likely faulty. If it is empty, fill it and bleed the system, then check for leaks.
May 30, 2012 | 2001 Dodge Ram 1500 Truck 2WD
On my 96 sunfire the clutch pedal went to the floor!! I still have half an inch of pressure from the floor and clutch will not engage reverse!! Any suggestions!??
does your car have a hydraulic clutch
just had similar problem on my Jeep had to replace the clutch master cylinder and slave cylinder.
you can bleed some clutch master cylinders removing air in system check fluid level full then bleed master cylinder keeping an eye on fluid levels not to run system dry..
good luck hope this helps (PTL)
Nov 12, 2011 | 1996 Pontiac Sunfire
My 1997 chevy 1500 z71 brakes suddenly going all the way to the floor. Checked brake fluid and it was low. Could be wheel cylinder? Master cylinder? or ?
well, check the brake lines for leakage after adding brake fluid to the full mark. If the brake pedal goes all the way to the floor, it's likely there is a leak somewhere after the master cylinder. If the pedal gets hard after adding fluid, and pumping it several times with the car off, then the master cylinder is still ok.
If air has gotten into the master cylinder, it may have to be bled out on a bench, or using a scanner if that's the way your vehicle is.
Bleeding the Brake System (ABS) Auto Bleed Procedure NOTE: Perform a manual bleeding procedure. If the brake pedal height and firmness results are not achieved, perform the auto bleed procedure below.
NOTE: Perform this procedure when replacing the brake pressure modulator valve or electro-hydraulic control unit.
  1. Perform the manual brake bleeding procedure. Refer to Bleeding the Brake System (non-ABS).
  2. Check the master cylinder fluid level often to prevent running the system dry.
  3. Press the brake pedal firmly and run the Scan Tool Automated Bleed Procedure (for Gas engines) once, or the Function Test (for Diesel engines) four times. Make sure to release the brake pedal between each test.
  4. Perform the manual bleed procedure again. This should remove the remaining air from the brake system.
  5. Bleed the system as many times as needed to obtain the appropriate feel of the brake pedal.
Dec 18, 2010 | 1997 Chevrolet K1500
My daughter's 1997 Camry V-6 - Clutch pedal will go to the floor and sometimes won't come back. Checked fluid in clutch reservoir - OK. No fluid leaking. Had her press the clutch pedal and everything...
try bleeding the clutch slave cylinder its just like bleeding brakes just follow the line from the clutch master cylinder where you checked the fluid to the slave cylinder and pump the clutch three times and hold it to the floor while someone loosens the relief valve you repeat until no air comes out and it is all fluid then you check you fluid level again to make sure it is full then if the problem continues it might be time for a clutch replacement
Oct 20, 2010 | Toyota Camry Cars & Trucks
97 Chevy Silverado Brake Problem
start bleding again from left to rigt all the way around.
Oct 09, 2009 | 1997 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
