Question about Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600 Overhead Cam
I have a honda 5 hp ohc pressure washer with an excell pump what kind of oil does it take
  • 30 Answers
SOURCE: I'm trying to find out how much oil should be in
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Posted on Mar 11, 2009
mcgyver468
  • 710 Answers
SOURCE: changing engine oil on a gx390 engine for pressure washer excel
On the very bottom of the motor is a square plug to drain the oil. The machine must be elevated to allow the oil to flow into a drain pan. If you don't see a square plug then look for a small 1/4 inch tube coming from the bottom of the crankcase with a hex cap on the end of it. If you cannot find either of these, then you must turn the pressure washer on its side and drain it through the same plug you fill from.
Posted on Apr 24, 2009
Editor925
  • 285 Answers
SOURCE: What gas and oil do I use on the Honda Excell 2600 pressure washr
That engine requires a separate gas and oil. There is an oil sump with oil level needle and cap on the side of the engine. This is where you fill it with special pressure washer pump oil available from any good outdoor store or place where pressure washers are sold. As for gas, Unleaded or Premium unleaded gas will work fine. Try not to use any fuel with ethanol blends however. Here is a list of oils that will give you an idea what to buy for the oil reservoir: http://www.amazon.com/gp/redirect.html?ie=UTF8&location=http%3A%2F%2Fwww.amazon.com%2Fs%3Fie%3DUTF8%26ref%255F%3Dnb%255Fss%255Fgw%26field-keywords%3Dpressure%2520washer%2520pump%2520oil%26url%3Dsearch-alias%253Daps&tag=onlinetoolrev-20&linkCode=ur2&camp=1789&creative=390957
Posted on Jun 15, 2009
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
SOURCE: Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Posted on Jul 22, 2009
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Feb 21, 2015 | Simpson MSV3025-S Megashot 3000 PSI Honda...
I am getting gas In the crankcase. engine back fires run only with choke out
float is stuck, bad needle and seat, debris between needle and seat and check air cleaner made sure it not oil or fuel soaked even if dry replace
Sep 18, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
The pump is leaking some gray fluid
Gray fluid is usually indicative of old oil with water mixed into it. First you have to determine if the fluid is coming out of the motor or pressure pump. Then change the oil in that, or both, and then watch the condition of the oil when you use the washer. With new oil, it won't turn gray but will get a milky coloration to it. There shouldn't be any way for water to get into the motor oil short of the engine being sprayed directly with high pressure water. If water is getting into the pump oil you'll have to check the seals inside the pump.
Feb 14, 2013 | Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600...
I need a owners manual for a pressure wahser GCV 160 from honda
MiTM will have that. See mitm.com Honda makes the motor but not the pressure washer. Honda does have manuals if you need one for that GCV160 motor.
Oct 20, 2012 | Mi T M Chore Master Pressure Washer - 5.5...
5 hp honda on a pressure washer. Bogs down and cuts off under load.
sounds like the pump has an issue check for restrictions in the hose as well as the filters look for any oil leak at the pump itself
Sep 03, 2012 | Honda Karcher G2400HH-R Pressure Washer
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
Honda 5hp 5 Hp Engine Motor Xr2500 Xr 2600 Overhead Cam Logo
76 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
