Question about Dometic Rooftop RV Air Conditioner
Propane furnace "POOFS" several times when starting heat cycle
Propane builds up in the heat chamber and when igniter turns on it "poofs" or has a mini gas explosion several times before the burners settle down and continue to burn correctly. Furnace does work correctly after several poofs. Burners were removed and cleaned and are in good shape, ignitor rod can be seen turning red, Could this be a regulator problem?
thanks, cliff
  • 463 Answers
I'm not sure how you are going to solve this, as propane's relative gas density is 1.55 times that of air, causing the gas to "pool" up in the bottom of the ignition chamber... After you are hearing the "poofs", the chamber is probably warmed up and the convection of the column of air rising then prevents the pooling of the gas towards the bottom. Hence the poofing goes away. Is there a pre-warmer or something that you are missing?...
Posted on Mar 12, 2009
Sounds as the regulator is not operating correctly (possibly the control board)
What to do with my furnace... When I turn it on it won't ignite, does anyone know how to fix this?
If it runs then there several things that could be wrong with it. one there might be something blocking the air flow which won't let it ignite usually mud dabbers like to build nest in furnace vents and intakes look in the vent with a light and see if this is the cause.
Aug 29, 2014 | Keystone 2010 Cougar 324RLB
Burner shut off then there is a clicking sound, burner ignites again
this is normal the clicking sound you hear is the system starting another cycle for your furnace to ignite the burners, then turn on tbe fan blower.
Sep 27, 2017 | Heating & Cooling
I have a Miller 90+ furnace running on Propane gas. We I start the furnace, everything is working perfectly except I notice that the first burner out of the 4 burners does not light. I have checked the...
Hi, propane gas is really hard on a furnace in causing a burner or burners to carbon up. Yes, there is gas coming from this orifice, what you need to do is grasp the burner from the front, lift the rear out of the slot it sets in as you pull forward, and take the burner out. Turn it over and clean it out. It may be full off rust and some carbon. You can do this, as it may take care of the problem. We have taken on some furnaces, if your home is heating fine on the 3 burners, and remove the orifice and just plug it off. Doesn't hurt anything at all, I believe its a 1/8 or 1/4' pipe plug. I have done this many times when the temperature rise is to high on a new unit, and the only option is to shut down one burner. No harm or adjustments needed. Try cleaning the burner first and make sure the tail end sets back in its slot. If this works, great, if not, plug it off and your set. Will save on your gas bill also.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Nov 08, 2010 | Heating & Cooling
H400FDN... Lights... burns for 5 secs... turns off... repeats...
Pull your heat tray and clean burners and check for rat nests. A common cause of this is spider webs in the gas orfaces on the supply pipe. If you remove the brass orfaces they may have small,small,small tiny webs inside them oyu can blow out or clear with a toothpic. they dirvet the gas from the main burner (the one with the ignitor) as the gas builds it will poof and start but then the other burners that have gas flow won't be close enough to let the ignitor read flame so it will cycle just like you describe. My kingdom for a toothpic. I have made a tool to do this out of a stripped wire bent just so with the end roughed up to catch the webs so I didn't have to pull the tray on heaters with this proble. You should pull the tray and see the whole problem to understand it better.. I hope this helps and good luck.
Oct 02, 2009 | Hayward H Series Pool & Spa Heater 400k...
When i start my oven in mt propane stove goes puff
disassemble and **** orifices and clean , spiders etc plug up all the time , propane is nothing you want poofing when igniting!
Aug 23, 2009 | Tappan MGF500PBW Gas Kitchen Range
Short cycling
There are a few reasons why your furnace is restarting after it reaches temp. and shuts off. First, if you have a mercury bulb thermostat it needs to be level and the heat anticipator needs set properly. If you have an electronic thermostat then you need to make sure the DIP switch settings inside are set properly for propane. If you have a digital thermostat there are also settings to be made for your type of heating. These settings will be explained in the thermostat installation instructions. Also, Make sure your furnace filter is clean. If this does not help then there are some other things to check which may need to be done by a technician depending on your mechanical aptitude. Hope this helps!
Dec 08, 2008 | Coleman Propane Forced Air Heater...
Dometic Rooftop RV Air Conditioner Logo
147 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
