Question about Hauppauge Wintv Tv Tuner Hauppage 48512 Rev I126 Ntsc/ntscj
Hauppauge Wintv Tv Tuner Hauppage 48512 Rev I126 Ntsc/Ntscj
2 Suggested Answers
adracamas
  • 344 Answers
SOURCE: I want free download wintv
You should be able to find your drivers in here along with the original softwares.
http://hauppauge.com/site/support/support.html
Posted on Apr 14, 2011
I have wintv-hvr-1950 hauppage box which suddenly stopped showing light. all things are connected as always - computer/internet working fine -Windows 7 - WinTVV7 screen opens black on my monitor
Make sure the power supply is working. Quite often you get a pretty crappy power supply with USB devices, so that is what I would suspect. Its a 5 Volt supply, and should get a little warm if its working. I don\'t think this device will work without a power supply.
Those supplies are quite standard, so bring your old one to Fry\'s, MicroCenter, Radio Shack, Best Buy, or even Walmart or the other stores to compare Volts, Amps, and polarity/size of the plug to make sure you get one that will work.
Sep 26, 2014 | Hauppauge Hauppage WinTV-HVR-1950 USB TV...
Tip
HP Express Card Digital / Analog not working
First thing I tried to do was to install the drivers that came into the CD didn't work, just using mydvd9 the import/aqcuire option I could have some noise signal, but couldn't find a way to select channels and hanged after a while. This is too trickier, I thought, it should be a way to used quickplay and other applications.
I couldn't get anything from HP site so investigating I found the following.
1) Had to upgrade quickplay to latest version (is pretty cool btw)
2) The card internally is a Hauppage and found that is actually the HVR1500 http://www.hauppauge.com/site/products/data_hvr1500.html.
Drivers + application can be downloaded at http://www.hauppauge.com/site/support/support_hvr1250.html
3) After upgrading quickplay and installing drivers and application from hauppage, Quick play had additionally an hp digital tv tuner entry, but here in canada there is no digital signal transmitted through antenna.
4) I have reinstalled manually the drivers that came in the CD, but from the c:\swsetup\HP Digital tv tuner folder
5) After this I had at quickplay a second source "Hp Analog Tv tuner" which allowed me to caputure the regular air signal and wintv worked as well
I'm sure that I did some redundant steps, but it worked and now can I have everything working (quickplay, wintv, digital, analog signals)
Hope this helps and btw I haev uploaded the manuals for thouse who can't get it, since HP doesn't have them in the website.
Cheers
Alejandro
on Feb 08, 2008 | HP Expresscard TV Tuner For Windows Vista...
I need driver for it
Hello seach by the product number here:
http://www.hauppauge.com/site/support/support.html
The number should be printed in somewhere on the device.
Here is probably only drivers for windows xp depending how old
the tuner card is.
Good luck
Nov 13, 2012 | Hauppauge 44801 Rev D110 Wintv-go Watchtv...
Driver downlod tv tuner 44801 rev d110
can you give me driver tv tuner 44801 please...........?
Oct 16, 2010 | Hauppauge Computer Work-3PO NTSC 44801...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Digital Transition
It's analog.  You need to purchase a digital receiver.  I personally have a USB external digital tuner running in Media Center 2005.  Search Ebay for "ATSC usb".  There's a lot of different options and most of them are pretty inexpensive.  To use a digital tuner in Media Center 2005, you have to leave the analog tuner / tuners in also.  You should still be able to use your current remote control with the new digital tuner.
Jan 25, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Bought This WinTV 44801 card in the store used " no drive'
Try This http://www.hauppauge.com/site/support/support_pci_boards.html
Jan 03, 2009 | Hauppauge Computer Work-3PO NTSC 44801...
No color from VHS on DVD/VHS player
There may be an input selection between Composite and S-Video that needs to be toggled in your Hauppauge software.
Your Hauppauge card may also be in the wrong signal format mode (NTSC or PAL). Your source device and your Hauppauge card need to be in the same mode (both NTSC or both PAL) for the capture to work properly.
If your NV-VP33 is a SCART output, then you may need to check your SCART adapter and your device as not all devices output both S-Video (Y/C - two signals) and Composite (CVBS - one signal) type signals.
If your SCART adapter has both Composite and S-Video outputs, try the other one.
And finally... if you're playing an NTSC tape/DVD in a PAL player, it doesn't mean the output is true NTSC 3.58. Most times it's NTSC 4.43 which is OK for TVs, but NOT okay for video capture devices. Video capture devices need true NTSC 3.58 to sync the color carrier properly.
Apr 29, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge Wintv Tv Tuner Hauppage 48512 Rev I126 Ntsc/ntscj Logo
199 people viewed this question
Top Hauppauge Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
k24674
Jay Plesset
Are you a Hauppauge Computer and Internet Expert? Answer questions, earn points and help others
