Question about Dishwashers
Frigidaire lfbd2409lm0a the water is standing in bottom.
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: standing water at bottom of dishwasher. Make and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 01, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: My Frigidaire dishwasher has dirty water.standing
    Two things to consider....clean water or dirty water?
    Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
    Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
    The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
    Posted on Aug 09, 2012
    Standing water in dishwasher
    Good Afternoon friend, thank you for your post!
    I understand that you have some standing water inside of your Frigidaire dishwasher. It is a normal operation to have anywhere from 2 to 3 inches of water inside of the tub of your dishwasher. If it is anything more than that you could have an issue with the drain pump or drain line.
    You may want to check the drain line for any restrictions or clogs that could cause improper siphoning from your dishwasher. You should also make sure that the filter located in the bottom of your tub is clean, that could cause water to stand within your dishwasher. I hope this information is helpful. -Matt
    Mar 11, 2015 | Frigidaire Dishwashers
    Dw180040 has water standing in bottom
    Check thaty your water pump and pipework are clear as thi will reduce the amount of water pumped out of the machine
    May 14, 2012 | Frigidaire Dishwashers
    Standing water at bottom of dishwasher. Make and model is Frigidaire Gallery
    heatman101
    Sep 01, 2010 | Frigidaire Dishwashers
    I have standing water in my dishwasher. How do I unclog the drain?
    It will be smelly water and if you have access to a shop vac that will help you remove the standing water if not use a bowl or turkey blaster listed below.
    Use a small bowl to remove standing water from washer to access screen to remove and check for blockage. Once you have removed all the water that you can with a bowl or cup. You can use a turkey blaster to sucton remaining water from dishwasher.
    Then you remove screen and clean out drain and also check drain line for blockage from dishwasher to under sink.
    Clean out drain to unclog in bottom of dishwasher and you may have to remove drain line to clean it.
    Aug 10, 2010 | Frigidaire Dishwashers
    This is because you have a problem with the diswasher pump and/or pump motor. There should NO water standing at end of cycle.
    Sep 20, 2009 | Tappan Dishwashers
    Standing water in bottom
    None. You have a problem with either your pump and/or pump motor.
    Sep 20, 2009 | Tappan MDB531RF Dishwasher
    Tappan Dishwasher w/ Standing water
    Try draino first then take it apart on the inside bottom to see what might be clogging it.
    Aug 04, 2009 | Dishwashers
    Water leaking from bottom ofoasis top loading machine
    you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
    Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Dishwashers Logo
    35 people viewed this question
    Top Dishwashers Experts
