Question about Video Game Consoles & Games
No power to my brother ae2500
No power changed fuse and tried different plug sockets not switching on and no light coming on either
Garfunkel01
  • 56 Answers
SOURCE: Power
return to store you bought from , or contact seller. if it's new, they should return and replace it.
Posted on Sep 12, 2007
  • 1019 Answers
SOURCE: power problem with nintendo wii
Lets Hope So ?
Check the main fuse in the 3 Pin plug ( if UK )
replace if blown, also check the wires are tight to the plugs pins.
Is There any light Indication On The power Pack/Brick with These ?
Could be a faulty Power Pack.
Check the leads are firmly connected, quite easy to knock a cable out, with an accidental kick or push of the console et,c.
Mike @ Compurepair.
Posted on Feb 28, 2008
melnavz
  • 1226 Answers
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
SOURCE: Samsung Flat screen 100hz tv - no power
My samsung flat screen tv have sound coming out but no display...anyway to check/help...
Posted on Aug 11, 2008
  • 86 Answers
SOURCE: wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Posted on Mar 25, 2009
Canon pixma will not switch on
Burnt fuse or double check that there is power at the socket and at the end of the cord when un-plugged... If there is power try turning on and make sure all doors are closed.
Nov 25, 2013 | Canon PIXMA Office Equipment & Supplies
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
Printer is currently offline
When you flip the power switch on the side, you should see either lights on the front or hear the fuser and cooling fan. If neither of these happen with the switch in either position, check the power cable and power socket it's plugged in to. If all these are OK it is likely that the power transformer inside the printer has died or the power switch itself has failed.
Oct 15, 2013 | Brother HL 1440 Laser Printer
Hitachi LCD TV Dead
There is a internal fuse on the power supply board. When you plug in the set, does the standby light come on?
May 10, 2013 | Hitachi 42PD7200 42 in. HD-Ready Plasma...
Will not switch on. The light does not come on when plugged in at the mains
check the power supply, most have a little light on. might sound daft but if its a uk plug or has a fuse fitted in the plug that may have gone. try a different power supply, maybe take to a computer store and just ask them if they will try it on one of their power supply's as a test, of it works you can get multi fit power supplies quite cheap from well known auction sites. if it turns out it is not the power supply, it could be a fault on your main board, a fault with the power in socket (i have a toshiba and the pin inside the socket always breaks off, ive changed it several times) or more commonly to the older generation laptops, it ould be the battery. sometimes the battery completes the charging circuit, again knock off batteries maybe found cheap from well known auction sites, and alothough not always of great standards, they are better than paying toshiba for one and finding its a board problem.
Nov 20, 2009 | Toshiba Computers & Internet
When i plugged in my new 2020 modem, the power light didn't come on, is there an on/off switch for this unit? Thanks.
There is no on/off switch. It only has a reset switch. It should get the power by connecting to the wall socket. Try connecting it to a different wall socket.
Oct 06, 2009 | Motorola Computers & Internet
Turntables
Your power transformer blew. The fuses in these models don't offer much protection, when it comes to more serious power surges. And the only other thing that would be blown is the transformer - a common issue. You can purchase parts for this model HERE, however, I do not suggest replacing this part yourself, as it is a little tricky, and you may damage your unit ever more, if not done properly.
- DJ PRO AUDIO
www.DJPROLAB.com
Jul 14, 2007 | Technics SL-1200MK5 Turntable
Video Game Consoles & Games Logo
15 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
