Question about Toshiba Tablets & eReaders
Wiring Diagram FOR PA3996U-1CAB Toshiba USB Charging Cable
Wiring Diagram PA3996U-1CAB Toshiba USB Charging Cable
Won't reload on my ipad
Connect to wall outlet Uses the USB power adapter and USB cable included with the device. If it is a third-party accessory, check to see if it is Apple Certified . Then follow these steps:
  1. Connect the iPhone, iPad or iPod touch to the Lightning to USB connector cable or the 30-pin to USB connector cable .
  2. Connect it to one of three power sources:
Wall outlet
Connect the charging cable to a USB AC adapter and connect the USB AC adapter to the wall outlet.
Computer
Connect the charging cable to a USB 2.0 or 3.0 port on a computer that is not in sleep mode. Do not use the USB ports on the keyboard.
Power supply
Connect the cable to a powered USB hub, docking station, or other Apple-certified accessory.
When the device is charging, you will see a lightning bolt next to the battery icon in the status bar or a large battery icon on the lock screen.
Aug 12, 2017 | Tablets & eReaders
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Charging port not working. How can I fix it
If it's a mini-USB charging port you could have damaged contacts on either your USB cable or the USB port itself. You should try another cable first hoping that it's only a damaged cable. If the new cable doesn't do it then it's probably the USB port itself. If that's the case, you probably have to take or send it in for repair.
Jul 28, 2015 | Tablets & eReaders
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
Why usb not charging tablet
that could be one of many reasons, anywhere from the charging port in the tablet, to a faulty wire in the usb cable, to a defective power source such as your computer's usb port. provide more information for better assistance please
Jun 06, 2014 | Tablets & eReaders
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
Mar 03, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
Thecharging port on my Toshiba tablet is broken, is there any other way to charge it?
I'm afraid there's no other way. Is there a physical damage on the charging port as evidence that you're saying it's broken? It might be the charging cable itself (hopefully).
Sep 22, 2013 | Toshiba Tablet. Excite 10.1 in. Android...
Kindle will not charge.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 30, 2012 | Amazon Kindle 3G
Tablets & eReaders Logo
429 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
