Question about Drills
What do the lights on a draper 40762 cordless drill charger mean?
Both red and green LED's are on. Is it charging, charged or faulty?
SOURCE: makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Posted on May 23, 2008
danny_murray
  • 55 Answers
SOURCE: Charger not charging
Does this happen to both batteries or just one if it is both then i would suspect the charger is bad and not the battery
Posted on Dec 04, 2008
SOURCE: skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Posted on May 09, 2009
  • 142 Answers
SOURCE: not charging
try wiggling the battery around and see if a light flashes
also look and see if a light flashes when you plug it in
i'm about 98% sure it's the charger
Posted on Oct 20, 2009
  • 142 Answers
SOURCE: Batteries not charging
sounds like my charger, not making good contact
wiggle the battery around while pushing down and you can probably get it to make contact
sounds like you just need a new charger
Posted on Nov 12, 2009
Black & Decker Cordless Drill will not charge battery
Either the charging adapter is faulty or the battery is worn out.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jun 03, 2012 | Black & Decker Black and Decker 18V...
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
Black & Decker cordless drill...how do i know it is charging? I am not sure i have the correct charger.
There are light on chargers, some red some green, red means chargeing, green mean charged.
Jan 17, 2011 | Black & Decker 18V Cordless Drill/Driver
Should the red light on the battery charger stay on, even when the battery is charged? Or does the continuous red light mean the battery will not charge?
I am not familiar with this model, but most chargers have a flashing light as the battery charges, and a solid light when it is charged. Do you have the manual? It should tell you what the lights mean.
Jul 17, 2010 | Powerglide Power Glide Cordless Drill
Charger doesn't charge anymore
If you are comfortable with removing the upper half of the housing, unplug charger and remove the screws, take a look at the circiut board for a "cold" solder joint or broken component, usually the round ceramic looking piece with the copper wire around it. but look at the whole board.
Jun 30, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I purchased a new charger for my Dewalt Cordless drill and the red light just blinks. Is this normal
They usually have a little pic on there that tells you what the blinking means. I think it is charging, but sometimes it needs a green light too. Check it out. Mine flashes all kinds of signals, when it hits a dead battery, one that won't charge, it flashes something else. It only takes an hour to charge. Is the battery getting charged at all? Hope this helps.
Apr 25, 2010 | Dewalt Drills
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
When I charge a battery, the red light on the charger comes on but never switches to green and I dont know how long I need to charge each battery?
the green light or LED indicates or sign the the batery you are charging is already full,.so if it doesn't happen to switch ,it means that your baterry is weak and can not reach anymore the amount of current or amperes needed thats why it cant go to the highest peak of charging just like when it is new.Replace your batery and the green light will switch again if it is fully charge.
Nov 22, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Skil cordless drill model 2362 - won't charge
Mar 30, 2009 | Skil 2362-01 Factory-Reconditioned 7.2V...
Drills Logo
70 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
