Question about HP LaserJet 4mv Printer
HP 4MV Printr and ip address
I have a HP 4MV printer with ethernet cable to my router which in turn also connects to my Mac G5 with OSX. Recently bought the wife a HP laptop with Vista. Wirelessly she can connect to the web, but cannot see the HP 4MV. Tried downloading the drivers, but still no go. I was then told to enter the ip address of the printer. I finally figured how to out put the data page which showed no ip address.
The manual does not show how to set the ip address. I'm lost. I'm ip illterate as well as pc dumb. Any and all help is greatly appreciated.
thanks,
garmp
    Genius:
  • 2,120 Answers
Scroll through the menus until you get to the I/O section. I don't think vista supports the HP 4MV
Posted on Mar 12, 2009
My Epson Label printer is showing as not connected when its connected, when trying to set up or add as new printer.
What shows mac and ip address ? printer or pc ?
If the printer displays them, it means the printer in connected to router electrically.
Check subnet mask and gateway address.
Could be set wrong if the router is not on DHCP.
I guess the issue is in the ethernet components / settings.
Start isolation by elimination of the following
1. Computer -
2. Wifi connection to the router (or)
3. Patch cable connecting computer to the wall -
4. Router -
5. Patch cable connecting the printer to the wall -
6. Printer -
The LAN printer cannot connect to Computer (PC/Mac) directly unless you use a Cross over cable.
Sep 11, 2016 | Epson Tm C3400 Securcolor - Label Printer...
Mac OSX 10.6.8 HP laser printer connected to ethernet port on router. Can connect and print wirelessly from one computer on network but not another. How to fix?
Can you ping from both computers? (Open terminal and try "ping <the printer's IP address>" obviously replace the <> with the IP of your printer) I'm not too familiar with Macs but can you comapre the driver version? If there is a universal HP driver, use that.
Nov 03, 2013 | NetGear WNDR3300 - RangeMax Dual Band...
My apple OSX 10.5.8 Always says my computer is not on line. How do I get it on line
Is you computer connected to your route via an ethernet cable? If it is, check the port on the router to see if the connection light is glowing. Next, check you network settings and set the "Configure IP Address" to be "Using DHCP". This will also the router to allocate an IP address and settings to computer. Now see if you can access the internet.
Snow Leopard Support
Mac Basics Connecting your Mac to the Internet
Oct 11, 2012 | Apple Leopard 10.5 Osx Mac Operating...
I've recently picked up a rio2e/tango2e card maker. I need to get a fixed IP address for the machine and will need to find the MAC address. I've been unsuccessful in finding the mac address (or static ip...
By default, the printers are set to take an assigned IP address from your DHCP server (or router) on your network. Connect it via the Ethernet port, then access the GUI for your server (or router) and check your connected devices - the MAC address for the Magicard printer will be presented there, along with the IP address that was assigned by the server (router).
Once you have the MAC address, you can then use "address reservation" features to ensure that a specific IP address is assigned to that device each time it is connected.
Aug 16, 2017 | Magicard Rio 2e - Ethernet - Single-Side...
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How do i add the mac address of my printer to the list of permitted devices
Disconnect the Ethernet cable between the router and the cable-modem (or DSL-modem).
Access the web-interface inside the router.
Allow "all" MAC-addresses to access the router.
Turn the printer off.
Turn the printer on, so that it gets a "fresh" IP-address from the router.
On the router's web-interface, get it to show a list of the "active" DHCP-connections.
It should show the IP-address and MAC-address for your printer.
Copy that MAC-address, and the MAC-address of your computer.
On the router's web-interface, access the table of "allowable" MAC-addresses.
Add the two MAC-addresses.
Enable the "selected MAC-addresses only" option.
Reconnect the Ethernet cable.
Nov 04, 2010 | Computers & Internet
Lost connect to all servers, internet and email
Create a new user account on your machine and use it. Your account might have gone bad.
Jul 02, 2009 | Apple Power Mac G5 Desktop
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
HP LaserJet 4mv Printer Logo
462 people viewed this question
Ben Johnson
