Question about Magic Chef CGR3742 Gas Kitchen Range
Gas range burner flame too high and too yellow.
I have just replaced the orifices in the Magic chef gas range Model # CGR1420BDW. I changed them when the gas tubing got kinked and broken (don't ask) Now the flame is very high and very yellow. The range is in a rural location that uses LP gas. Now I wonder if the stove was ever converted for lp from natural gas.
Is there a way to check? Is there a conversion kit? Or a conversion switch or dial? Any other ideas?
  • Magic Chef Master
  • 3,361 Answers
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Posted on Mar 12, 2009
We have a magic chef gas stove with sealed burners. were trying to change it over from natural gas to L.P. do we haveto have different orfaces?
Do you have your owner's manual? It will tell you how to convert it to propane and what size orifices to use with each burner. Not all the burners are the same size, so you will need this info in order to install the right size orifices. The data plate on the oven, which is usually behind the bottom pull out drawer, will tell you what the BTU rating is for each stovetop and oven/broiler burner. If you don't have the owner's manual, reply back with the exact model # you have (it's listed on the data plate too) and I'll look it up for you. You will need a small nut driver tool to change the orifices. As soon as you provide more info, I'll try to help you further. Douglas
May 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Have a 1986 Fleetwood Park Model with a Magic Chef gas oven that will not light. The pilot is lit but the oven burner will not come on. Uses propane gas...it worked last year.
Propane is a "dirty" gas. That can sometimes result in a particle of debris getting lodged in a pilot orifice, causing a low pilot flame. Inspect the burning pilot, look to see that the pilot flame encompasses the thermocouple so that the thermocouple may get hot enough to open the gas valve. If the pilot is too low, sometimes tapping on the pilot assembly with some handy tool will dislodge any restricting particles from the pilot orifice and restore flame size. Make sure that the pilot or thermocouple have not been struck by some object and knocked out of place. If the flame and thermocouple seem OK, you may have a bad thermocouple. Before replacing the thermocouple, loosen and re-tighten it's connecting nut at the valve (follow the thermocouple "wire" to find the valve) , if the connection is poor, sometimes that will restore good contact.
Also to note: the pilot will be at minimum when the control valve is "off", the pilot flame size should at least double when the control valve is turned on. Be careful, that is gas you are working with.
Feb 03, 2010 | Magic Chef Kitchen Ranges
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Burner flame height adjustment
All ignitors will always arc whenever one of them does.
I haven't worked with propane systems much, but it seems you may need the propane pressure regulator adjusted.
If the problem is only with the power burner, I would ensure that particular orifice was actually changed. The hole in a propane orifice is smaller than for natural gas.
Jan 08, 2008 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Magic Chef CGR3742 Gas Kitchen Range Logo
870 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
