Question about Xerox Phaser 6100/BD Laser Printer
Toner empty Using too much toner
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Add black toner but still empty
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Jun 03, 2014 | Ricoh Aficio SP C820DN Laser Printer
Minolta 4695 claiming the yellow toner is empty, but it's full??
using 3rd party toner or OEM. use OEM and replace the Image unit with OEM.
May 30, 2014 | Konica Minolta Magicolor 4695MF All-In-One...
Printer display message (toner empty replace toner) and printer stop printing..
replace new cartridge or reset printer using reset software (firmware)
May 21, 2010 | Samsung SCX-4300 Monochrome Laser...
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
Put in second toner and machine is still saying toner empty
If you are using refilled cartridges those errors are common, Samsung has an eeprom on the cartridge keeping track of usage and you need a new chip from the refillers. If you are using OEM cartridges you need to clean the contacts inside the machine that the cartridge connects to and wipe the contacts on the cartridge before installing, Otherwise a shop repair for the CRUM circuits.
Sep 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Toner empty display
If you are using the Toshiba supplied toner cartridge then properly changing the cartridge should automatically cause the unit to reset. If not, try turning the copier off, unplug it from the wall for 3 minutes then plug it back in and turn it on.
Dec 22, 2008 | Toshiba E-Studio 160 All-In-One Laser...
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
Xerox Phaser 6100/BD Laser Printer Logo
14 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
