Question about HP Compaq 6735s Notebook
I have a hp 6735s with win vista installed in it. i want to use win XP but it wont install in this computer system.what should i do?
  • 1,223 Answers
Problem : When Windows XP was made there was no concept of SATA drives now ur drive is SATA and ur installation disc does not contain drivers for ur Hard disk thats why it is unable to find ur hard disk as it doesnt recognize it u need sata raid drivers on ur windows inst cd
this specific model HP 6735 was shipped with vista OS and drivers now u are downgrading it to XP it depends on the installation disc if it is new one like SP3 included then u would have never faced this issue in ur case u should get a RAID driver from and then include them in ur copy of windows XP cd to load them at the startup of installation , so u need them in the first place to carry out installation, u have to do some job here download RAID DRIVERS from select ur board and chipset either it is 945 or 965 gm and then download nlite a software used to integrate these drivers to ur inst disk , u can also include SP3 thru this software in ur current win xp cd
just download sata drivers from intel and nlite from the link and install the software integrate these drivers and burn ur cd incl them and then install normally as u were installing them earlier now it will recognize ur drive simple for more info how to do check this out
pls dont forget to rate me fixya for this help if u like
pls let me know if i can help u more
Posted on Mar 12, 2009
  • 10 Answers
Try disabling the achi in the bios thats when you get to device config in the bios when you do that then you can run your winxp installation....
Posted on Sep 25, 2009
You have to disable AHCI in th ebios and run the HDD as IDE. Win XP won't pick up the hard drive under AHCI.
Posted on Jun 05, 2009
Can't get printer installed
Depending on your operating system, the driver is available for download or built into your operating system. If you have Vista or Win 7, power your printer up and plug in the USB cable to your computer. The operating system will install the driver by itself. If you have Win XP or Win 2000, goto and then type in your printer and choose Software and Drivers. Click on drivers once it expands and download the driver to install it.
Feb 01, 2011 | HP PSC 1210 All-In-One InkJet Printer
Installer of hp Deskjet 810C on on my laptop since I could not use my hp deskjet 810C printer
Can you please verify that the drivers that is installed for HP 810C is proper as per the operating system.
EX: if you have Win XP then you need to install the HP 810C driver for Win XP. If you have Vista's driver for that printer then it would not work.
So install the proper driver as per the operating system and everything should work fine.
Jul 23, 2010 | Computers & Internet
Windows xp
You don't need to buy another license for XP, you can use your old license.
Feb 25, 2010 | Microsoft Windows Vista Home Premium...
Hp 6735s screen blank problem
If you use it from the power cable does it work better? There is a known issue with the 6735s and power management settings from battery.
Oct 02, 2009 | HP Compaq 6735s Notebook
Can i run vista and xp on my comp
install the two OS in separate drives (e.g. XP in C drive and vista in D drive) either have two hard disk drives or 2 partitions.
then you choose which one to run in the start up.
May 11, 2009 | HP FK784AA Pavilion Slimline s3650f...
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
No sound in win XP sp3
please check out in my computer systems device manager if anything in the sound section is in red or yellow remove it. unless win xp was made for your laptop the drivers are not there. you need to go to compaq web site and download your drivers.
Nov 28, 2008 | Audio Players & Recorders
Win Vista and Win XP Probs?
which applications are not compatible? Do you try to run them in compatibility mode set at windows XP?
You may install VMWare Server to run a virtual machine XP from Vista without dual boot, allowing running XP and Vista at the same time, its easy to install/configure, need a good computer with 2Gb ram min.
Jul 04, 2008 | Microsoft Windows XP Professional With...
I want to install xp over vista in hp laptop
do you want to replace vista or run double OS's, in other words you would be prompted to select either or operating system to use prior to loading screen.
Dec 13, 2007 | Microsoft Windows Vista Ultimate Edition
How to install XP on pre loaded Vista in HP Laptop what can i do
make sure you have taken all the backup of your data from your system bcoz xp will not overwrite on vista you need to be format your drive which will erase your data. for installing windowx xp you need win xp cd as well as all the driver for win xp bcoz the driver is diffrent for vista and win xp . if you have windows xp bootable cd just place in your cd-rom or in dvd rom .and go to bios setup (bios setup is just press the del button from your keyboard or f2 key it is display whrn you start your system )and change the booting sequnce from hdd to cd rom when it will boot from cd one massage will come press any key to continue just press the space bar and follow the setup instruction . if you need more help let me know bye
Sep 28, 2007 | Microsoft Windows XP Professional With...
HP Compaq 6735s Notebook Logo
558 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
