My Raheem furnace keeps going out - Heating & Cooling
How to bleed water furnace
Maintaining water pressure and keeping the circulator pump running, go to the furthest bleeder and remove any air at each bleed port working your way back to the furnace. You must maintain water pressure or you will have to start all over again.
Jan 10, 2015 | Heating & Cooling
Username login
Username and login for what/where? You appear to be logged in to FixYa with the username "raheem scatliffe."
Dec 29, 2013 | Computers & Internet
I HAVE A NORDYNE E2EB 015H
Sounds like the flame sensor is dirty or bad. This is a metal rod that sits on the flame telling the controls that the burners is lite and it is okay to keep the gas valve open. If there is no flame it tells the control no flame shuts the gas valve off to keep excess gas from building up in the furnace. It could also be a faulty limit switch which tells the control the furnace is to hot so shuts the furnace down till it cools off. This is easy to check with an ohm meter with the furnace off check for continuity through the switch(usually a round disc looking thing with two wires going to it) if it ohms out then it is okay then run the furnace and after it shuts off check the switch to see if it ohms out if not then you have found the problem if it is okay could be the flame sensor try to clean it with a lit grit sand paper or emry cloth works good.
Jan 13, 2010 | Heating & Cooling
Carrier super saver furnace keeps going on and off
Sounds like the flame sensor is dirty or bad. This sits in the burner flame when the burners are running. This usually has a single white wire connected to the back of it.
Jan 03, 2010 | Dayton Gas Furnace Heater
Dial of panasonic KX-TG2620BX is locked
dial locked problam plz recived my file just replay.....................
Regards,
Shaikh Raheem
9823004576
Jun 22, 2009 | Panasonic KX-TG2620B Cordless Phone
Carrier Furnace keeps going through ignition switchs, could it be
This is actually the wrong place foe this however there is an overload on the circuit which may be caused by a faulty ground on the circuit.
Apr 29, 2009 | 1997 GMC Jimmy
Sound Driver Is Not Supporting
Dear Abdul Raheem
These Server Operating systems have compatibility issues with some hardware. I would do the following:
Get updates from the 2003 Server site; it checks for drivers also and updates them.
Write Acer Tech Support, tell them you want updated drivers for XXXXX soundcard.
Put your CD with sound drivers in drive. Go to hardware install in C-Panel and ask it to search for updated drivers on the CD. Or Right Click My Computer> Properties> hardware and select the yellowed gizmos. One of them will be your sound. Right click and select UPDATE DRIVER with the CD already on drive. Follow instructions. If you don;t have such a CD for your soundcard, find the drivers from Acer tech Support.
Barabara?
Nov 22, 2007 | Acer AOpen AW 200 Sound Card
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
