Question about Fish
Rotted wood fix - Fish
How do I repair the rotten wood on my deck
Once you have dry rot in a deck it is very hard to stop completely. It is a fungus, and spreads tendrils in the wood grain. Repairs have to involve chopping away all the rot to sound wood, and then treating it. Simply painting it with something s ineffective.
There are many commercial fungicides, all poisonous, so take care. A popular DIY treatment is a mixture of glycol (concentrated auto antifreeze) and borax, with a bit of liquid soap.
There is usually a lot more rot than meets the eye, often in the joists and bearers. The strength of the decking can then be compromised, and if concerned, ask a builder.
You are often best off just ripping out the whole lot, and replacing it with preservative treated timber which will never get the same problem.
Aug 09, 2016 | Garden
When I step on the step of my 1995 Colman pop up the left panel lower wall panel pulls away. How do I fix it?
not an easy fix . you have to open the wall up and replace the rotted wood with new good wood .
Jun 22, 2016 | RVs
Does uncovered firewood stored outside go bad?
Sounds like someone cut down some trees and stacked them in your yard. Most likely, it is good firewood. Actually, covered wood rots faster than air exposed wood because of lack of venting or direct exposure to the sun which dries up exposed wood. Covered wood stays wet longer which accelerates rotting. Thick round logs are hard to burn because they are not split. If you feel up to it, you can split them and burn them in your fireplace. Good healthy exercise!. If not, then Crags list would be my choice also.
Briketter
Dec 15, 2012 | Woodland International Chainsawbuddy...
Dryer vent goes thru anuninsulated outside wall causing the outside wood to rot. what do I need to do to correct this problem?
You need to remove the vent and replace/repair the rotted section. Paint the repair w/ a good quality exterior paint. When replacing the vent, be sure to caulk around the flange to prevent water from entering and causing more rot.
Aug 16, 2012 | Dryers
What is better to buy; a wood or plastic picnic table?
It really dependswho you ask, but I think plastic is longer lasting that wood when it comes to picnictables. Many plastic tables are treated with molded in color and wont splinter,stain or rot like wood can.
Jul 25, 2012 | Furniture
How do you fix a soft closing toilet seat where one hinge has become loose, one side has become detatched
Sorry there is no fixing one. the reason the hinge probably came loose is the wood has cracked and/or the wood got wet and rotted and the screws won't stay tightened. Go to Walmart and get you a new seat.
Jan 29, 2011 | Home
Fish Logo
113 people viewed this question
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
