Pmx2000 has lost some of the signal in the left output
The left side of the output has a lost full sound, it is like the top end and low end are lost. Right side sounds fine and bridge output is fine too.
4 Suggested Answers
Ooq Affiat
  • 76 Answers
SOURCE: The left side main output won't put out any sound.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Posted on Oct 21, 2009
linswad
  • 258 Answers
SOURCE: Right speaker is distorted with low volume, left
There is something wrong with the right channel amplifier, you need to get this equipment serviced.
Posted on Mar 26, 2010
pctech1
  • 1940 Answers
SOURCE: No problems for several years. Yesterday the right
  1. Check for resistance in your Right side speaker. If the speaker died, the Receiver may have shut down the right side outputs.
  2. Test the Right side with a different speaker if you can.
  3. If the tape monitor switch is turned on, turn it off.
  4. In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furthest.
  5. Check different modes such as Natural, Hall, Stadium, and see if the speakers are working.
  6. Try disconnecting the power, reseating all connections on the back of the Receiver, reconnect all speaker wires, reconnect the power.
  7. Make sure any DVD players, TVs, etc. are plugged in properly, and reseat the connections.
  8. If you are still experiencing trouble, the device will require internal repairs. Contact a stereo repair shop to get a quote for the repairs.
Posted on Feb 22, 2011
Need to wire up a factory radio plug for 2003 chevy tahoe z71 with bose premium system. need to know what wire gose in what pin in the plug. SOMEONE PLEASE HELP ME!!! PLEASE!!!
Connector Part Information
12110088 (Except UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRY) (Except UQ7 w/o Y91)
15428074 (UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRN) (UQ7 w/o Y91)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2
Not Used
A3
PPL
493
Rear Seat Audio Enable Signal (UQ7 w/o Y91)
A4
RED
1486
FM Composite Signal (UQ7 w/ Y91)
A5-A7
Not Used
A8
TAN
201
Left Front Speaker Output (+) (UQ3/UQ5)
A8
TAN
511
Left Front Low Level Audio Signal (+) (UQ7)
A9
GRY
118
Left Front Speaker Output (-) (UQ3/UQ5)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-) (UQ7)
A10
LT BLU
115
Right Rear Speaker Output (-) (UQ3/UQ5)
A10
BLK
1946
Right Rear Low Level Audio Signal (-) (UQ7)
A11
DK BLU
46
Right Rear Speaker Output (+) (UQ3/UQ5)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+) (UQ7)
A12
BLK/WHT
1851
Ground
B1
ORN
340
Battery Positive Voltage
B2
Not Used
B3
PNK
314
Radio On Signal (UQ7 w/o Y91)
B3
DK GRN
145
Antenna Enable Signal (UQ7 w/ Y91)
B4
BRN/WHT
230
Instrument Panel Lamps Dimming Control (w/ Y91)
B5
BLK/WHT
1851
Ground (w/ Y91)
B6
GRY/BLK
2334
Radio Mute (UQ7 w/o Y91)
B7
Not Used
B8
BRN
199
Left Rear Speaker Output (+) (UQ3/UQ5)
B8
BRN
599
Left Rear Low Level Audio Signal (+) (UQ7)
B9
YEL
116
Left Rear Speaker Output (-) (UQ3/UQ5)
B9
DK GRN/
WHT
1547
Left Rear Low Level Audio Signal (-) (UQ7)
B10
DK GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-) (UQ7)
B11
LT GRN
117
Right Front Speaker Output (-) (UQ3/UQ5)
B11
LT GRN
512
Right Front Low Level Audio Signal (+) (UQ7)
B12
Not Used
Oct 20, 2015 | Cars & Trucks
VR3 200 AMP
Looking at this picture you can see the terminals at the top.
This installation has one speaker hooked up on the right, and the power inputs hooked up on the left.
The inputs will be power on the left, 12 volts positive (V+); a signal wire for to power on the amp that's 12 volts positive too, (V+, It's usually a yellow wire that comes out of the car stereo called To Antenna, or To Amp. and the third connector on the left is a Ground, or 12 volts Negative (12-). Look for the labels V+ and V- to get the power connectors in the right places. (I can't tell from the picture which is which)
On the left side is the Speakers, Each speaker has a positive and negative lead, and the terminals on the amp are labeled Left + and Left - and Right + and Right - .
Align the speaker leads to the terminals (in cars a negative lead usually has a stripe running along the length of it, and a positive has no stripe).
On the other side of the amp are RCA sockets, one red one white. Any low signal can plug into these, from an Ipod to a turntable. Your car stereo, or EQ, will have RCA outputs that can connect to these with an RCA Patch cord, which has plugs on both ends that will fit into the RCA sockets. Whatever signal goes into the RCA inputs is amplified out of the speakers when it works.
Nov 01, 2012 | Car Audio & Video
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
I need a circuit diagram for a Behringer PMX 2000 to repair a left hand power output problem
Here you go..
I posted your schematic on my temporary web files site; so,
download and save within the next two weeks cause it might go away..
http://ca.geocities.com/artiedc/PMX2000.pdf
Ed
Jun 21, 2009 | Audio Players & Recorders
Tapping sound for left side of motor the head
if its the 3.1 or 2.8 engines this is a collapsed lifter. it is normal. your local G.M. dealer has a oil additive that will fix your noisey lifter.
May 24, 2009 | 1995 Isuzu Rodeo
I got 4 ''15 inch kickers 2 5500watt power acoustik mono amps my problem is 2 kickers on the right side hittin hard but the 2 on the left not.i thought the amp on the left was bad so i took the rca of the...
Hello herb31,
It sounds like there is a difference in the signal levels on the inputs to the amps. You did not specify what the RCA's are connected to on the head unit side. If they are connected to a stereo pair of preamp outputs, you may be able to solve the problem by using only the channel with the higher signal and use an RCA "Y" adapter to split it to both amps. If they are connected to a dedicated subwoofer output on the head unit, make sure that the head unit is set for "subwoofer". Some less expensive head units, I know JVC in particular, has only 1 set of line outputs and requires you to go into their "PSM" (Preferred Setting Mode) to set the line output mode and if you select "subwoofer", then allows you to select the low pass frequency.
If you are converting speaker-level outputs through a "line out converter", check both the input and output levels.
Also, if you are splitting an output from the head unit, you still need to connect 2 RCA's to the amp inputs. The signal will be properly split if you use a 1-female to 2-male "Y" adapter. To feed the same signal to both amps, you would need 3 "Y" adapters. Feed the output signal to the female end of the first "Y", and plug the male ends into the other 2 "Y" adapters. Then, the 4 plugs you have left on the ends go into your amp inputs.
Hope this helps.
Apr 24, 2009 | Power Acoustik CLASS D SL-5500D Car Audio...
Transceiver signal interference
The FT-840 uses a die-cast RF power amp with thermally switched fan to ensure full power output (up to 100 watts). The digitally synthesized local signals ensure clean, low-noise transmitter output on all HF amateur band. There might be no AC line interference. it has strong Rf output. any AC line intersect does not affect its radio performance. Check and adjust RF power so to maintain proper output. some times more RF power generated at the output may cause interference. adjust Rf power..Even some unfiltered Noise getting the other end of the end may calso cause interference. Check for any Ripple voltages present at the output. Contact authorised service station for further Rectification. thank you shanth
Dec 23, 2007 | Computers & Internet
22 people viewed this question
 Grubhead
Grubhead
