Question about Hamilton Beach Water Cooler with Storage Cabinet
Drinkwater is not running
We have a hamilton refrigator and the water stopped running.
  • Cordula Claxton Mar 12, 2009
    For more help the refrigerator is the model no.: GSL25KGREBS and it is the side by side one Thank you for help!
  • max4fitness Mar 26, 2009
    My cold water side is not working...How do you remove the filter?
  • 205 Answers
Filter is plugged or supply hose is pinched. Turnoff the water supply before you remove the filter.
Posted on Mar 18, 2009
My Hamilton Beach just stopped working
Have you tried cleaning it? Try runing equal parts vinegar and water through your coffee maker. Then flush it by running to cycles of water through it afterward.
Nov 05, 2017 | Hamilton Beach Coffee Makers & Espresso...
I have a GE refrig. model GTS22ZCMARCC. The evaporator fan has been pulsing up and down forever. Then the freezer stopped getting cold and the refrig. part was not as cold. I check the evaporator fan...
it's the board,also change out the sensor that's on top of the coil,it looks like a white bullet,the part number for the temp. sensor is wr55x10025 and the board is WR55X10942.everything runs through the board,i've seen when you call for water the compressor stops or the water doesn't dispense,or the fan pulsates like you have.let me know how you make out
Oct 21, 2010 | GE GTS18SHPBS Top Freezer Refrigerator
Model gsl251grb water dispenser stopped working. r&r filter no help. turned temp down in case froze, no help. can hear motor run. ice maker works. help
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Nov 13, 2009 | GE GSL25IFR Side by Side Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Won't Stop Cooling
thermostat is stuck. try buying a water cooler control from a local supply house.
Apr 24, 2008 | Hamilton Beach Water Cooler with Storage...
Hamilton Beach Water Cooler with Storage Cabinet Logo
108 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Dan Webster
Dan Webster
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
