Outdoor fan motor E12 A58 301 - Heating & Cooling
2 Suggested Answers
  • 3 Answers
SOURCE: Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Posted on Aug 14, 2009
What to do with carrier infinity ac fault code 81
"Low capacity thermal lockout"#81. What this tells me is your 1st stage cooling(low capacity) is locked out for 4 he's due to a dirty outdoor coil, weak outdoor fan motor run capacitor, slow outdoor fan motor, overcharged with freon, restricted or short cycling outdoor airflow(overheating), damaged discharge temp switch, faulty outdoor circuit board. That's all the scenarios I can think of for now. Hope this helps!
Aug 24, 2017 | Carrier Heating & Cooling
Air conditioner outside fan does not turn off
Is the compressor shutting down and fan is not??? How about the blower, is the coil freezing? Need to check the contactor on the outdoor unit, 240 volts hurts, please use caution. If not confident as to what you are doing call a professional. If need be turn off breaker, you do not want the coil freezing inside!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 19, 2017 | Heating & Cooling
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
Power indicator just keeps blinking
H16 on this model means that either the power supply transformer has failed, The outdoor PCB has failed or the machine is low on gas.
This info is from the Panasonic service guide. The outdoor unit LED 1 is on, LED 2 is on, LED 3 is off, LED 4 is off.
H16 On On Off Off Current Transformer Problem Power Transistor Module or Outdoor PCB Faulty. Very Low Gas
Mar 28, 2014 | Panasonic Heating & Cooling
IR 6000 - Error conde E10,E12 and E14 after 5 to 10 min of starting
Error E10/E12/E14: Main cause: The main motor (M1)(M2)(M19) is faulty. The DC controller PCB is faulty.Mode of detection:0000 The clock pulse do not arrive for 2 secs or more after the main motor drive signal
For more help you can check the canon iR6000 service manual from below link:
http://goo.gl/yhuA4J
thanks
Jan 12, 2013 | Canon Service Manual For Ir 6000
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
Got a 52" heritage ceiling fan from meijer and it uses e12 candalabra bulbs. Doesn't come with any and no local stores have them. What is the deal?
My local Home Depot stocks these, as does Ace Hardware.
You can also buy them online if you like (that link was just the first shopping link from googling "e12 candelabra bulbs"
Just be sure to rate my fix as "helpful" before you go shopping! :)
Aug 17, 2009 | Heritage (5BFW52NK4KG) 52'' Ceiling Fan
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
The fan in the outdoor unit does not work while the AC is on. The inside unit blows the cold air and the compressor in the outdoor unit is working the fan was not. How this issue can be resolved?
these motors are famous for the inyernal fuse blowing in the fan motor. check continuity between the red and blac wires. if there is non the fuse is gone. These motors are fairly easy to take apart and change the fuse . hope this helps
Apr 24, 2007 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
