Question about Gateway GT5056 PC Desktop
At about 3:00 am on thursdays, Windows XP closes and C drive shuts down. It is not a re-boot because the motherboard power stays on. When I turn the computer off and turn it back on (the 1st time)it freezes before windows starts up. On the 2nd try windows opens normally like nothing ever happened. I am running a Gateway GT5058. The internal hard drive failed about a year ago and was replaced under warrantee with a Western Digital 320 GB hard drive. Jerry
  • Anonymous Mar 18, 2009
    Response to request for clarification. No, it does not happen every week. But it always happens early in the mornings. Between 2:00 and 4:00 am.
  • Bharat Das
    Bharat Das May 11, 2010
    Does it happen every Thursday, I mean ,does it happen like it is scheduled ?
    Novelist:
  • 148 Answers
Sounds like the computer is coming from sleep, standby or hibernation mode. Go to the power settings in the control panel, and disable all of these options. Disable your screen saver as well. Leave the machine on for a day and see if it happens again after this. Post your findings, please...
Posted on Mar 22, 2009
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Computers & Internet
Dell code 2000-0148
It could be the motherboard, but it is more likely to be a hard drive. Back up anything you need as soon as possible and replace the drive and re-install the operating system(Windows)
Jul 28, 2013 | Dell Latitude D630 Intel Core 2 Duo T7250...
Can't install windows XP on new hard drive
That problem is from HDD, It can be bad sector on MBR \ on line for boot record\. Change your hard disk , if it in warranty , will be well.
Nov 24, 2011 | Biostar G41D3C LGA 775 Intel G41 Micro ATX...
Running Windows XP, 4 Gigs ram, P-4, 3.0 gigahertz. Infinity 865 PE board. Computer wiill boot up, then shut down. No blue screen or any warnings. Sometimes it will not even make it to the login screen and...
This could be a problem with your power supply.
1. If you have recently added or changed any of the components in it or have something connected to it (like through USB) that draws power right away, the power supply might not be able to handle it and will shut down. A good way to test if this is the case is to go unplug a few devices you don't need right away for the boot up (like your CD/DVD drives) and try to boot up. If it boots up just fine and stays on then thats most likely your problem!
2. It could also be that your power supply is going bad. If its old this might be the case. If you take it all the way down to the bare essentials (power supply, CPU, ram, motherboard, video card, hard drive) and it still does it, chances are you need a new power supply.
3. A few other things to consider: - check to make sure you have good air flow. If the fans are covered in dust ( specially the CPU fan and heat sink ), blow the dust out with compressed air. - Also there is a small chances that it could be your hard drive failing. If the first two options here don't get you anywhere, you might want to try a different hard drive or booting from the cd/dvd rom drive with a bootable disk. But this should be the last thing to try if nothing else works.
Again, this really sounds like a problem with the power supply, either not having enough power to run everything or going bad, so try those test first!!
Hope this helps!!
Feb 17, 2011 | DFI 865PE-ML (865PEML) Motherboard
WINDOWS NOT SHUTTING DOWN COMPLETELY
dude i think its the BIOS prob try reseting the bios u can do so by removing the maotherboard battary for one min aand then replacing it this will surely rester the bios.this should it
Feb 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
You will need to enable the Advance power management in Bios and on windows..
Try to see in the bios the advance setting for APM.
Some motherboard you have to enable this.
Other its simply on windows.
After the installation of windows
Go >Right click desktop>properties>then select screen saver tab>below click power>
Then click APM tab
enable and restart
May be this can solve this issues.
Or else I would advice to change the power supply and see.
Regards
uttam
Feb 03, 2010 | Computers & Internet
Hi When I try shut down the pc Windows XP will close leaving the power supply, cpu,fans, usb still running To shut down the pC I have to turn off the power switch at the rear Please help
This issue also cause by a hard drive errors, check your hard drive for errors. In My Computer window, right click Local Disk C select Properties, go to Tools tab, click Check Now button, put check on Automatically Fix Errors and Recovery of Bad Sectors, then restart your computer to run the check disk operation.
Also read this solutions regarding about Windows XP Shutdown and Restart Troubleshooting
http://www.aumha.org/win5/a/shtdwnxp.php
Jan 26, 2010 | Abit IT7-MAX2 Motherboard
Windows XP will not shut down.
I don't know if you've tried this yet,but here it is just in case.
Click Start, and then click Control Panel > Performance and Maintenance>Power Options>In the Power Options Properties dialog box, on the Power Schemes tab, click the Power schemes drop-down list and select the power scheme that most closely matches how you use your computer.
adjust the System standby and System hibernates settings if you are not happy with the default selection. On the Advanced tab, you can adjust the default behavior of the power buttons on your computer. Click Apply>OK
Please rate this a fixya
May 21, 2009 | IBM IntelliStation E Pro 570 (689357U) PC...
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Gateway GT5056 PC Desktop Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
