Question about Panasonic Palmcorder PV-GS120 Mini DV Digital Camcorder
Focus The focus lens of my camera got wet and now it does not zoom in or out and the image is not clear. Is there something I can do to fix it myself?
  • 73 Answers
Ebay a parts camera - with a working camera ( most ' as is ' have tape problems ) , get jeweler ' s screwdrivers and take pictures ! as you begin disassembly - so you can put it back together ; a good technician can do the swap in 2 hours from start to testing ( your pictures will be interesting , whether you finish or not ! )
Posted on Aug 05, 2007
SOURCE:
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
My web cam 4tech is not clear
Is the audio not clear or the video not clear?.
If the camera is plugged in and installed correctly then you should be able to open up a web cam program like skype, gmail or messenger and test out the camera, as well as adjust the camera's settings.
If the camera lens does not have auto focus, see if you can move the camera lens around in both directions. Some cameras have this for manual focusing. If you cannot access the camera lens then it SHOULD have an auto focus feature.
Also, play around with the camera settings (brightness, focus, zoom, sharpness) to find the best combination of setting for your environment.
Older cameras dont have very good resolutions so don't expect a high quality image or frame rate.
Mar 05, 2011 | A4tech PK-635 Webcam
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Macro shots on a cloudy day...
do you really need to use tohe zoom function when in macro mode? remember the lens has it limit on distance of the taken subject. Try to experiment without using the zoom and doing some distance adjustments
Aug 10, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Camera doesn't focus
There are many reasons why images can appear out of focus. strangely if you think about it it is not focusing per se like photographic cameras the focus is at infinity by default- from about 50cm - out So if the images appear out of focus these are some of the reasons shots taken in low light with a low ASA setting resulting in long exposure -thus camera shake. Focus hunting- there are various methods used but if the mechanism cannot 'lock' onto something the focus motor will 'hunt' Faulty zoom Optic Zoom mechanism. Inadvertently set to 'Macro' mode Grease on the lens Careful checking of the camera- its settings- with the manual is essential before declaring the camera faulty Don't forget the paper manual is a nodensed version of the full manual on the software disk.
Sep 02, 2007 | Cameras
Focus Problem
A small amount of dirt on the lens would just produce some flare and redule overall contrast slightly. It wouldn't produce a grossly out of focus image. Either you misaligned something or you messed up the autofocus system somehow. Can you focus the lens manually. Many consumer grade digital cameras allow you to set the focus at some specific distance. Do that measuring the distance carefully, and see if the image is still out of focus. Digital cameras tend to have a lot of depth of field, so there must be something seriously wrong with the mechanism.
Sep 12, 2005 | Fuji FinePix 2650 Digital Camera
Focusing the 770
Tom, It's best to do the zoom first, then focus (if you are using the autofocus).
Sep 11, 2005 | Sony Cyber-Shot DSC-D770 Digital Camera
Panasonic Palmcorder PV-GS120 Mini DV Digital Camcorder Logo
73 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
