Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
My came up with the fo2 code and the fdl code. After about an hour of cleaning the drain pipes and the whole drain system it worked for 1/2hr. Today I get the same codes and nothing works It will not drain or spin???? Any idea what it is???? The washer is only 7 years old now that I turned around it has the SUD code flashing HELP
  • suprnol Mar 12, 2009
    I did that last night and it worked for a 1/2 hr. any other ideas?
  • 478 Answers
Remove the lower front lower panel there is a strianer in pump it unscrews check that first
Posted on Mar 12, 2009
  • mark milligan
    mark milligan Mar 12, 2009
    Replace the pump.65.00
F2 code coming on several times during a wash
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Regarding 'suds', the junk in your filter could be affecting the thin tube going from the pump area to the 'pressure switch' near the controls. This should not be blocked, remove clip from top & blow into it (after cleaning out the filter). If blocked clear it out. Do not wait for filter to clog up. Check it now & then, according to usage.
Nov 06, 2009 | Kenmore Elite 45986 Front Load Washer
Going to Fo2
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washing machine model 110 he3t code fo2
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Pl. rate me nice for the free help!
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
Fo2 on screen
your pump is jammed clean or, replace
Aug 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL DUET MODEL GHW9150PW1 doesnt complete wash cycles
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 04, 2009 | Whirlpool Washing Machines
Code f02
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
It stops in the middle and says 02 f
Apr 02, 2009 | Kenmore Elite 45986 Front Load Washer
F02 error on my kenmore elite H3
Apr 01, 2009 | Washing Machines
FO2 Error Msg
ok now ,,check why water is not leaving machine on time,,,check your drain pipe,,check the drain hose,,just blow in it and make sure a coin not stck there ,,the same with the waste pipe,,onthejob
Feb 18, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
FO2 AND SUD
hAVE YOU TRIED UNPLUGGING FOR A LONGER PERIOD SO COMPUTER LOSES ITS MEMORY.
Dec 23, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
