Question about Maytag MBF2256H Bottom Freezer Refrigerator
Remove shelves from bottom freezer compartment maytag
Need to get back off to defrost drain
  • 1462 Answers
SOURCE: Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Posted on Jul 25, 2007
SOURCE: maytag side by side, bottom freezer compartment had daily ice build up
I had the same problem with mine a couple of months ago. There is a drain which gets plugged. You have to remove the contents of your freezer, and then look at the back area of the freezer. The panel that's on the back is removable. Once it's removed, you will see a drain at the bottom. Mine was clogged up with debris, and was covered with ice. I poured warm water over the drain, soaked it up...did this a few times to melt the ice, then I worked at cleaning out the drain. Mine wasn't plugged too badly, I ended up having to blow air through the drain using my air compressor, to be positive that it was clear of debris. You could poke something down the drain, but it won't go very far because there is an elbow on the drain tube(visible on the backside of the unit itself)
If you get it cleaned out, it should be fine. Mines been great ever since I cleaned mine out...no more puddles on the floor.
Posted on Feb 18, 2008
SOURCE: maytag refrigerator MSD2454GRW shelf removal
The above answer is only HALF right. The blue clips have to be removed to lift the shelf up and pull it toward you.
To remove the clips:
1. Get a screw driver or something to get behind the clip.
2. Slide it behind the clip and slowly pry it toward you.
3. Repeat for the clip on the other side.
4. Do the above; lift the shelf slightly and pull it toward yourself.
Posted on Mar 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Freezer cold- Fridge not. Ice build up on freezer
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. appliancepartsouteast@live.com
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://appliancepartseast.blogspot.com/
http://servicepartstec.blogspot.com/
Posted on Aug 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: MAYTAG MTB2156GE REFRIGERATOR. NOT GETTING COLD.
Whatever you do do not run the refrigerator with the freezer fan not working. That Fan is about $70.00 depending who you get it from and easy to change. If you could find someone we could do it without calling service, that is what we are here for. See if you can find someone with a digital meter and let me know when ready, Sea Breeze
Posted on Feb 17, 2010
Why Icing on bottom freezer
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
Aug 18, 2014 | Whirlpool Whirpool 26 cu. ft. French Door...
Where is the defrost drain
Back behind the metal "wall" at the rear of the freezer, there is a raised "shelf" with the drain in it. Pull our freezer racks or shelves, remove a few screws, renove sheet metal "wall", and you will find it at the bottom there.
Jul 22, 2014 | Maytag Refrigerators
Maytag fridge RTT1900DAE - need instructions/diagram to access defrost heater, defrost timer, and defrost thermometer, so I can test them all. Haven't been able to find anything helpful using Internet...
defrost timer should be in the refrigerator side behind the temp control knob, defrost heater and thermostat should be located in the freezer compartment behind the cover plate for the fan. Just remove your shelves and you will see the screws holding the cover plate on, remove them and you will see the coils and fan. Thermostat / heater are at the bottom of the freezer coils
Sep 17, 2013 | Maytag Refrigerators
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Maytag MFI2268veb there was a slab of ice that we removed from the bottom freezer after removing the freezer compartments but couldnt locate the vent pls help
Your drain pan in the back of the freezer is clogged and when you unit goes into defrost this happens. I would turn off the unit, remove the racks and shelves, remove the back wall, at the bottom is the pan, use hot water and a turkey baster or a cup to thaw the ice and clear the pan. Make sure you clean out the drain tube also. Lastly turn back on the unit, I forgot once....
Good Luck
Aug 14, 2011 | Refrigerators
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
My Roper refrigerator has water inside it at the bottom and on lower level shelves. How can I correct this?
Good luck
I hope this helps
Gene
Aug 01, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
How can I access the defrost heater on maytag model rtd21a freezer/ref? I see only one screw in the freezer compartment. I have replaced defrost heaters in whirpool and kenmore. There are screws in those...
The defrost heater sits behind the evaporator coil. The evaporator coil lies horizontally between the freezer and refrigerator compartments. It is a lot of work to get access to the defrost heater. To do that you will need to remove the shelving in the freezer, both the refrigerator and the freezer doors and the trim pieces between the freezer and refrigerator compartments and remove the plastic liner at the bottom of the freezer. Once you removed the plastic liner, then you can see the evap coil and the heater is way in the back of the coil. Good luck.
Jul 01, 2010 | Refrigerators
Water drains to the bottom INSIDE the refrigerator and ice forms on the bottom of the freezer compartment
The defrost drain hole in the small tray at the back of the freezer is frozen over. Turn off the refrigerator. Remove the shelves and bins from the freezer. Carefully break up the visible ice and dispose of it.
Use a hair dryer to defrost the drain hole. It will be a slow process. Be patient.
Jan 07, 2010 | Whirlpool Refrigerators
Maytag MBF2256H Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
