Question about Ovens
Neff Oven handle loose
We have a neff oven B1430W702 and the handle has come loose. It appears to be attched by 2 screwws from inside the oven door. Can the inside oven door be removed to access these 2 screws or will be need a new door? My model is a neff E1420 Double oven with loose handles and no way of accessing them
  • tibeton Mar 12, 2009
    there are no screws on the side of the door. only screws are by hinges, which only let bottom of door slightly open. Rest of door secure at top where handles are. It looks like handles screws hold top of door in. No access to handle screws from outside.
  • Barry Kimber Jan 13, 2013
    Be careful - on my neff oven the spring clips are only at the bottom of the glass and release was easy. The top of the glass is secured by two metal tabs that are not made to release. Open door fully and prize the inner glass panel upwards to release the two lower clips. glass release
  • 478 Answers
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
Posted on Mar 12, 2009
Yes well had same problem but the inner
glass plate is only fixed by spring clips and when you take this off you can then access the handle screws dont overtighten them because there is a brass ferrule inside that will shear off if you do
Posted on Mar 03, 2011
I have the same problem. Did you ever find the solution
Posted on Oct 27, 2010
Oven door handle one side not attached to door other side loose
look around the outer edge of the door a few screws hold the 2 halves together caution do it on a flat surface as the glass can fall out .
Sep 01, 2016 | Neff Ovens
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
I have had both door hinges replaced on the main oven of my Neff but the door still does not close properly. What is the next step?
I would have gone straight through Neff. If it can't be fixed, your'e supposed to get a new oven out of the deal.
Apr 29, 2012 | Neff U1461 Double circotherm plus Electric...
How do I sepate the inside from the outside of a neff oven Bl641 door
Remove the oven door by flipping the hinge catches into their alternative position and lift the door out of the hinge slots (note it is somewhat heavy). Lie the door, outside face down and press down on the glass with both hands until it slides off the mounting pins at the base of the door body. Replacement is an exact reversal.
Feb 18, 2012 | Neff B1641 Single circotherm super...
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Apr 15, 2009 | Neff B1421 Electric Single Oven
Ovens Logo
1,650 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
