Question about Whirlpool WED9200SQ Electric Dryer
My duet dryer wed9200sqo will not come on when i push the start button
  • 262 Answers
SOURCE: my dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Posted on Dec 29, 2007
Illeagle
  • 525 Answers
SOURCE: dUET dRYER 9250
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If this doesn't help, post me back and I will do some more research to help resolve your issue.
http://www.repairclinic.com/0088_8_1.asp#Level1_14
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 27, 2008
thaurfen
  • 623 Answers
SOURCE: dryer will not start
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
Posted on Nov 13, 2008
SOURCE: Duet whirlpool dryer not running
If it is the 9400 series, the door has 2 latches. It must be shut firmly to connect. Sometimes it will take 3 or 4 firm shuts. I feel it is a design flaw of the door. Hopefully this helps as I have been struggling with it for 2 years.
Posted on Jun 06, 2009
SOURCE: The unit is a duet dryer ser#wed9200sqo unit will
my whirlpool dryer duet model wed9200sqo, everything comes on but when i push the start but it just makes a sound like like it want to start but won't, would i need to put a new start switch in it?
Posted on Jul 12, 2011
How to replace start button on whirpool duet model WED9200SQO
Hello. If the outer soft-touch button is damaged, you will need to replace the outer console assembly, part# 10116694. If the internal button is damaged, you will have to replace the "center user interface board) part# w10031410. This is an INVOLVED repair. If you haven't worked on a dryer, don't attempt this. The top cover must be removed by removing its screws at the rear of the dryer. Slide the cover back about an inch and lift it up. POWER MUST BE REMOVED AT THIS POINT. The control panel has the boards mounted to it by screws--the function dial must be transferred to the new board as well as other parts.
Aug 13, 2015 | Whirlpool Dryers
Start button gone how to start model number WED9200SQO
Call a repair service to replace missing start button
I have new dryer Whirlpool duet push the button it turn on but push the start button and it does not work
dryer under warranty just CALl the company got from an they send service tech out
Feb 15, 2015 | Whirlpool Dryers
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Hello....I have a Whirlpool Duet Gas Dryer, model WED9200SQO. We have it for about 4 years. It will not power on. It is just DEAD!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 26, 2011 | Dryers
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
The unit is a duet dryer ser#wed9200sqo unit will not heat up
Mar 18, 2010 | Whirlpool WED9200SQ Electric Dryer
Duet 9250 dryer. Won't start up. I did bridge
try the door switch. in some models you can jump the wires to see if it starts.hope this works.
Jun 23, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool WED9200SQ Electric Dryer Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
