Question about Boston Acoustics Horizon Solo Clock Radio
Boston Acoustics Solo clock radio volume level not immediate
I have a new Boston Acoustics Solo table top AM/FM radio. It is their
new model that replaces their Receptor radio. I notice that when I
turn the Solo on that it takes about 2 to 3 seconds to play at the
full volume it is set for. The volume quickly gets louder but it is
NOT instantaneous, like it is for their older Receptor model. Is this
normal behavior for the Solo?
The radio does come on immediately, the slight delay is only in the
volume rising to its full volume.
The Solo has what they call a super capacitor to hold a small charge
to keep the time settings saved for about a day if the power goes out.
Perhaps this slight delay in getting full sound volume is related to
the design of this capacitor.
A tech guy with Boston Acoustics via email says it sounds like it
might be a bad capacitor & wants me too mail the radio to his repair
center.
I prefer not to go through the trouble of packing it up and mailing it
out for service if this is normal behavior for the Solo. What is your
advise?
  • 2 more comments
  • iGreg Mar 12, 2009
    So this does not sound like normal behavior? I would also note that the volume and other controls are on a spinning window on front of radio that allows radio to be vertical or horizontal. I am suspicious that this may be the nature of the design of the radio, particularly if it is only issue with volume control. Radio sounds super. It does turn on immediately.I just notice that its sound quickly escalates to the volume it is set for, rather than instantly as in their older Receptor radio.
    I do not understand either of these responses, can you rephrase them?
    "yes. it very common on the one that you have, a semi manual dialing selector may came up with this problem,"
    Are you saying this is normal behavior as a result of design and I should not worry about it?
    "have you try adjusting it into full volume and leveling it into normal?"
    Do you mean simply raising to full sound volume then down to listening volume and then turn radio off and turn on again?
    I was not asking for a new "solution" I just wanted the previous solutions clarified by their authors.
    P.S. I do not know if I want to start spraying fluids into the radio, except maybe for some compressed air. I never did anything like that before.
    Well I am lost now anyway since I can no longer see all the previous proposed solutions.
    New Friend:
Old thread, but in case anyone reads this, it is NORMAL.
Posted on Apr 06, 2016
  • 15,935 Answers
This is a built in "feature" of the radio.
Its called a "soft-on" so if you accidentally leave the radio on loud in a loud environment, it wont blast you from your chair when you're in your livingroom and forgot to turn it down.
As far as changing a capacitor - you can easily check for damage by opening up the case (if you are so inclined) and inspect for bulging caps... however the volume "issue" is a standard feature - also more prevalent in cars now too.
Radial capacitors are relatively easy to replace if need-be. The information is printed right on the side.
Again, though, your radio has this featuer by design.
Thanks for using FixYa!!
Posted on Mar 12, 2009
  • 564 Answers
You can call your Product Support number
You can reach Tech/Product Support Home/Car Audio 9:00 AM to 5:00 PM ET, M-F at 201-762-2100
Product/Technical Support
support@bostona.com
Thanks,
PREM
  • 58 Answers
It is probably the capacitor problem like the tech guy said.I would advise you to get it looked up by Boston Acoustics rather than try to search for a problem youre not too sure bout.
This is a common problem occuring with the Solo although it isn't normal behaviour.If its still under a warranty you can get it doe for free.
If i helped you make a decision and solver your problem in any way...Please click on the FIXYA rating for me.
Thank you.
  • naveengopi
    naveengopi Mar 12, 2009
    Anyhow,before you open it up or call the tech guy again...try the following.And if still aint workin...you gotta call the guy.
    Turn the unit on
    Turn the volume down to minimum, 00, volume
    Press and hold power for 10 seconds until volume numbers flash
    Turn the volume back up to 50 (max volume)
    Press power again to verify new max volume position
    Thank you.
  • 167 Answers
Hi, i would unplug it for the day, buy some electrical contact cleaner- the quick dry formula (radio shack or other electronic store) use the little injector tube to get in tight spots spray the controls then work them, while unpluged! then wait an hour, plug it in and try again..the volume may just be a little stuck, make sure you get quick dry, as it evaporates in seconds! hope this helps you. good luck!
  • glenn hoffman
    glenn hoffman Mar 12, 2009
    hi,it is an evaporating chemical, not like water. i have used this stuff for a long time-and on my high end audio equipment. it does clean switches, buttons, radio and television tuners, especially volume controls. i think it is a bad contact, this is why i offered this fix. i would get a replacement under warranty if you think it is defective(before that is not an option) hope you find the answers you need. have a nice day!
    Brigadier General:
  • 3,614 Answers
IT SEEMS THAT THERE WAS A BAD CONTACT ON THE VOLUME CONTROL, BETTER DO CLEANING
  • 2 more comments
  • micromaster
    micromaster Mar 12, 2009
  • micromaster
  • micromaster
    yes. you got what i mean.
    means very common problem, not normal and needs to be check and repair
  • micromaster
    A COMPRESSED AIR WILL DO. DO NOT USE LIQUID AS WHAT YOU SAY.
Why will my volume will not go past 10 on my boston duo i plus radio?
To perform a "soft reset"(all settings are erased)
Unplug radio
Hold alarm 1 button and plug in radio
Keep holding alarm 1 button until 3 numbers appear.
Release alarm 1 button and unplug radio.
Plug radio in and all will operate normally
May 21, 2014 | Boston Acoustics Horizon Solo Clock Radio
Tuner doesn't work
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off.
Mar 29, 2014 | Boston Acoustics Horizon Solo Clock Radio
From US fm/am to Europe fm/am
Hello
Contact
Boston Acoustics, Inc., 300 Jubilee Drive, Peabody, MA 01960 USA
Jan 07, 2012 | Boston Acoustics Recepter Clock Radio
My volume will not go past 10on the display and will not go any louder.
Turn the main (volume) knob all the way until volume reads 00, leave the button (volume) pressed until the radio beeps - be patient it takes a while - after this turn the knob all the way or until you reach an acceptable volume limit, push the knob again until beep then turn radio off. This should take care of the problem.
Dec 19, 2009 | Boston Acoustics Horizon Solo Clock Radio
How can I find the product manual for the Horizon Solo Clock Radio?
Here you go buddy:
http://www.abt.com/images/products/PDF_Files/hsolomdnt_use.pdf
Nov 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
Volume won't go past 30
Turn on. Set volume to 00. Press & hold the volume knob for about 10 sec., until you hear a beep. Then turn volume up to the maximum that you would ever want, and then press the volume button again. It is now set.
Feb 02, 2009 | Boston Acoustics Horizon Solo Clock Radio
Boston Acoustics Horizon Solo Clock Radio Logo
442 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
