Question about Acer Aspire 5050-3242 Notebook
Cracks near hinge Acer 3613 laptop
Large cracks have appeared on the outside bottom left hand and right hand side of each hinge on my Acer 3613 laptop. They are going to et bigger each time I open the lid and I dont want the problem to get any worse. Is there anything I can do like use silicone sealant or does anyone know of a better solution. My husband suggested Duck tape!
  • heathersim21 Mar 13, 2009
    Tried lubrication but hasn't seemed to help. How do I unseat/unscrew hinges to re-tighten little screws I dont know where to start?
  • 463 Answers
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
Posted on Mar 12, 2009
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Black spot appeared on the screen on bottom left side how to clear it
A large black spot usually means the LCD screen is damaged. It may have fine cracks around the black spot. In this case the LCD screen needs to be replaced.
A replacement screen maybe available for your laptop from this WEB site.
LCD screens and Inverters www.lcdparts.net
Feb 12, 2013 | Lenovo Computers & Internet
Frigidaire dishwasher (FDB1100RHC2) is leaking from bottom right corner and it appears there are small hairline cracks on the plastic tub. Is there a way to repair them?
Hello - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, from what you have described it sounds like the springs or hinges may possibly be damaged, or gasket not sealing properly. I would strongly suggest contacting a professional to move forward accurately.
Oct 12, 2012 | Electrolux Frigidaire Professional Series...
Hi, my daughter has a dell inspiron 1545 laptop which is about 18 months old. today when she turned it on , apart from a 3/4 inch strip on the left hand side, the screen had a pattern resembling a large...
i think this is fixable, but just professional teachnician from service center can fix it, you just go to service center, and ask for fix that error
Dec 02, 2010 | Dell Inspiron 9100 Notebook
Crack to hinge and lid of laptop
just be carefull when opening or closeing undo catgh then lift from as close as possible to hinge to stop stress on cracks to close do same.
hope this helps.
Apr 28, 2010 | Computers & Internet
Acer laptop crack at the back of LCD near the hinges.
In my experience, I have been able to replace the LCD Bezel to fix the crack. You can order this from any online parts store if you are a Do-It-Yourself type or any computer support company could help. Good Luck
Frank
Jul 27, 2009 | Acer Extensa 503T Notebook
Acer Aspire 3613 cracks near hinges.
you can lift up the little round circles take out all screws,take top off, to lcd find the little gold nuts that the screws go into, try to put them back in plastic holes with super or gorilla glue,
or order screen parts on ebay, hinges usually get worse unless you find a way to secure those brackets attached to hinges
Mar 13, 2009 | Acer Aspire 3613WLMi Notebook
My laptot as started cracking near the left hand hinge
superglue it or epoxy it back together. that's about all you can do.
Feb 05, 2009 | Acer Computers & Internet
My maytag side by side model #RSW22EODAM refrigerator door has a
If all you need are shims, use washers (either plastic or metal) with an interior hole large enough to go over hinge pin to raise door. However, in reading your complaint, I feel as though shims (or washers) may not solve your problem. You may have an issue with the door seal and or door liner. Sometimes a new seal will correct the problem but check for any cracks in the door liner. If cracks are evident, you will need to replace both. Putting a door seal on a cracked liner will NOT help. If you need to replace both, it can get a little costly. Good luck.
Dec 06, 2008 | Refrigerators
Cracks in case around hinges.
Replace bottom plastics. Find them by doing a Google search. Use keywords 'laptop plastics for make/model.
Jan 06, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 5050-3242 Notebook Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
