Question about Pioneer PRO-200 60" Rear Projection Television
Pioneer Elite PRO200 PROBLEMS
I have two problems. Maybe they are related. First problem. TV will be running fine, then suddenly I hear a loud ZAP, and it goes out. I can hear what sounds like a relay clicking on an off a few times, them it just stops. If I turn power completely off then back on after about 30 minutes, it runs again. Then happens all over. Second problem. Picture turns all blue and red. By using the secret repair technique ( banging the side of the set with my hand) some times it will fix it self. I have had nothing but problems with this set since I purchased it. Not sure whether or not to junk it and buy a flat panel. Thanks
  • 2 more comments
  • Anonymous Nov 15, 2007
    My tv will aslo will be running fine, then suddenly I to hear the loud ZAP, and it goes out. I can hear what sounds like a relay clicking on an off a few times, them it just stops. If I turn power completely off then back on after about 30 minutes, it runs again. Then happens all over. Can someone tell me what causes this. I need to get this fixed quick...Thanks.
  • jayarbass Dec 29, 2007
    Where is the deflection board?
  • JAW II Jan 02, 2008
    For a couple of days now it will just shut dowm. Now it shows to power on but with no picture, light is red, almost as if it is stuck in stand by mode
  • Bolotte Jan 07, 2008
    My TV just shut down and will not turn back on. I am getting a red light next to the power button but can not get it to turn green. I have turned the power on and off with no success. I have tired our gaming system with no success. I have un plugged it and let it set with no success. the local repair center wants $100 just to come out and diagnose. Please help.
    Problem Solver:
  • 13 Answers
You need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
BUT DON'T DELAY AS SOONER LATER TV WILL NOT RESTART..
http://www.avsforum.com/avs-vb/showthread.php?t=402397&pp=30&page=38
Good luck.
cell
Posted on Jan 16, 2008
  • 39 Answers
TEAMPRO-THAT MODEL IS KNOWN FOR LOOSE CONNECTIONS ON THE DEFLECTION PCB.YOU CAN A)ORDER A NEW DEFLECTION PCB,OR B)TRY RESOLDERING ALL CONNECTIONS UNDER THE DEFLECTION PCB ESPECIALLY NEAR THE FLYBACK TRANSFPORMER.JOE TV
Posted on Nov 27, 2007
SOURCE:
I'm having problem with sound when I use my Pioneer Elite VSX-32 receiver. Everything is fine if I directly connect to my TV with HDMI cables from my cable box or my roku box. However, if I use the same...
check the audio output settings of your components. THey may be set for dolby digital which your receiver can process but your TV can not. Try PCM stereo setting or "other".
Apr 29, 2014 | Pioneer Audio Players & Recorders
Tip
Pioneer Pro Elite Rear Projection TV with Sudden loud pop then shuts down
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
Good luck.
cell
on Jan 16, 2008 | Pioneer PRO-200 60" Rear Projection...
Hdmi picture sound pioneer elite pro r04u
disconect video cable from the box and if you see color video bars on the screen the problems is the box.if you dont see anything you problem is in the display
Nov 10, 2013 | Pioneer Televison & Video
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Pioneer GM-6200F amp appears to have blown, but fuses are intact
I have used Pioneer before but have not run
across this before.sounds like you may have
drove it a little to hard, and and zap one of your amps inside.Take the top off and look
around and smell.
Maybe This Will Help
Sep 09, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Toshiba 62hm94
sounds like a connection issue between the lamp and ballast.
Nov 13, 2008 | Televison & Video
Replacing power board on pioneer pro 200 elite
364.00 for a new Power/deflection board through pioneer. i am including a link to their site. You may find it cheaper someplace else on line, but pioneer will have better quality parts. hope this helps. heres the link.
http://parts.pioneerelectronics.com/model.asp?modelNum=PRO200
Jan 15, 2008 | Pioneer PRO-200 60" Rear Projection...
PRO-100 Pioneer Elite
convergence can not go all a suddenly it might be due to magnetic affact.if it is so remove it very near to tv or you must have tilted tv due to some reason. if it is due to ckt near e/w correction.
Sep 14, 2007 | Pioneer PRO-100 TV
Pioneer PRO-200 60" Rear Projection Television Logo
2,031 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
