Dlink 2540u red power light stays on - Computers & Internet
3 Suggested Answers
SOURCE: DSL 2540u internet speed problem
I found the solution for the speed problem.My isp use G.DMT so just put the tick on G.DMT and take out all tick on adsl, adsl+2 etc.
Posted on May 02, 2009
sfender713
  • 397 Answers
SOURCE: My dlink dsl-2540u router not
Contact your ISP immediately- the issue you have is called no sync. Basically with the DSL led going completely off- that would point to a bad modem, however the fact that you have no sync otherwise indicates your DSL provider may need to service your DSL line.
Posted on Jul 12, 2011
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
Older XBox 360 with wireless antenna - can't connect to network - why not?
What color does your wireless adapter (xbox) turn when you power on your xbox? Green, Red, or Grey (No light)?
If it's grey(no light), try connecting the adapter into one of the USB ports in front of the console(the usb ports are behind that flap)
If it's red, it's a hardware problem and you should try and repair it.. or replace it (xbox antenna).
If it's green, then it's something to do with your network settings.
Good Luck
Jan 12, 2013 | Video Game Consoles & Games
My dlink dsl-2540u router not connect to the internet. Dsl led blinking & sometimes totaly off.
Jul 09, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Which is the latest firmware update for the 2540U Router? http://ftp.dlink.ru/pub/ADSL/DSL-2540U/Firmware/ is the only site I can find with updates on it but I'm not sure which to choose.
Make sure you download the correct firmware for you Hardware.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of you router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Apr 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Why does red light on "on" button stay on?
The reason the red light on your rinnai vent free gas heater stays on simply is because it is having power on it, if it is unplugged, it will go off, or if you turn off the switch from the power outlet, then it will go off too.
As long as there is power supplied to the rinnai vent free gas heater, the power light will remain on.
Take care and good luck
Dec 01, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Power red light solid
I have same problem. I was able to manually assign IP of 192.168.1.2 and was able to connect to 192.168.1.1 (the d-link) but it keeps asking for Factory Supplied Firmware From ISP. I flash it with the firmware but then it crashes again.
Jan 04, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Installed dlink, says hardware is not found. power light is also off.
If all lights on dlink are off, start by check the power supply. If its connected from the wall to the dlink and still the light are off.
  1. The power supply is bad
  2. The AC from the wall has no current. Check for these.
When you succesfully turn on the dlink, connect the cables as directed. by the manual.
Jul 14, 2009 | D-Link Xtreme N DIR-655 Wireless Router
May 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
No power
cain9:
If I am not mistaken I think you used the power adapter from 302g to 502t?, if yes try simply using the adapter that came with 502t, also please try any other power source from wall socket and try replacing your power bar. If nothing comes up then it could be hardware failure.
I had the same issue with my Dlink router but that was simply the power surge that effected my Dlink router as being continous ON.
I recommend to start using power surge they add a little cost but are really big time savers for things which have to stay ON.
Hope that helped!
Dec 07, 2007 | D-Link DSL 302G (DSL-302G) Modem
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
