Question about Toshiba Computers & Internet
Hi, I have problem on Toshiba Insyde H2O bios. It says press F2 for setup and F12 for boot manager. I've tried all the function keys it not work,but if u type ctrl alt del it work pls help
MysteryFCM
  • 187 Answers
SOURCE: Failure to boot
In these cases, I'd strongly recommend checking the RAM to ensure that isn't the problem. If the RAM is fine, then the issue is likely with the laptops motherboard. In which case, it would need to be sent back to the manufacterer.
Posted on May 25, 2008
  • 66 Answers
SOURCE: bios stuck
did you try removing each stick of ram individually or the hdd then rebooting?
Posted on Nov 03, 2009
  • 1481 Answers
SOURCE: Bios stuck on my toshiba L305D-S5934 it not doing
u can re-set the BIOS by removing the BIOS battery, the BIOS battery(wrist watch cell) is the size of a Dime inside the laptop, so you need to open the laptop, i suggets you visit a technician to do this.
Try doing the following also.
remove the power adaptor and remove the battery from the notebook, keep pressing the power button for 3 - 4 mins. Refit the battery / power and re-start.
Posted on Dec 07, 2009
  • 164 Answers
SOURCE: BIOS POST message cannot be displayed and Setup does not run
As soon as your computer turns on, start pressing F2 simultaneously until it enter the CMOS setup.
Posted on Jun 06, 2010
engineerayo
  • 169 Answers
SOURCE: A disk read error occurred Press Ctrl Alt Del to
These problem is usually caused when the harddisk of the computer system is Bad.
THE SOLUTION:
Purchase another HardDisk and Prepare it for use by formatting and installing the Operating system on it.(either Win7,win vista etc....)
pls remember to rate me as soon as you get this message
Posted on Dec 24, 2010
Bios setting probleme
you can not press the F12 or F2 Key at startup ....You need to hold the key down abd bios will open of boot order if F12 is pressed.
So hold the key down(F2,F12) then press the power key...keeping the F key pressed down.
Good Luck
Jun 19, 2013 | 10 10 Computer Network adapter Cable...
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
I'm trying to help a friend install
After "Fast Boot" has been enabled, you cannot access the BIOS setup during power on . The machine will bypass "Press F2 to access Setup Utiltiy and F12 for Boot Menu" prompt.
This is a bigger issue if the hard drive crashes and access to Windows is not possible OR
Fast Boot can be enabled or disabled in the BIOS setup, or in HW Setup under Windows.
If you have Fast Boot enabled and you want to get into the BIOS setup. Hold down the F2 key, then power on. That will get you into the BIOS setup Utility.
You can disable the Fast Boot Option here. You will need to disable Fast Boot if you want to use the F12 / Boot menu.
Aug 26, 2011 | Toshiba Computers & Internet
HI..i have a lenovo G550 laptop... the problem is that i can get in to BIOS or BOOT menu i've tried every key F2 F12,, nothing works..pls help me..
Try with External USB Key board. To enter BIOS setup utility, press F2 when the Lenovo logo appears during starting up your computer.
Hope this helps to you....
Jun 18, 2011 | Lenovo G550 Notebook
I restarted my Toshiba satellite a305 and now it won't boot up or go into safe mode. It comes to the start up screen that says press f2 for setup f12 for boot manager. It will let me go into setup and boot...
If it won't let you go to safe mode,then there's something that the BIOS(setup) or Boot Manager needs before starting the operating system(Windows Vista). You should have a Toshiba Recovery Disk which will fix this . The disk will not touch any of your current files and data,so don't worry about that.
Apr 12, 2011 | Toshiba Satellite A305-S6908 Laptop
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Laptop A3 not booting up
Sounds like your hard drive is not booting and that your keyboard isn't responding to your pressing F2 and F12. If you can locate a USB external keyboard or if you have a round PS2 port for an external keyboard/mouse - plug into the laptop with that then press F12 while the computer is booting, press it a few times to be sure you get it in the buffer - then the boot manager should show up. If it does, choose to boot the Hard Drive if available - same with pressing F2 - Setup or Bios CMOS Settings should be displayed, here you can try to boot from the Hard Drive or Check to see if the hard drive is being recognized or not.
You may need a new keyboard if your laptop keyboard doesn't get you into either menu, and to either make sure your hard drive is responding and can be set to be the default boot device.
Mar 23, 2009 | Toshiba Tecra A3 Notebook
Can not change Bios Boot Device
remoove battery n start
press f8 n safe mode
shut down n restart
press/dell/f2/f10/f12 key
then u will go to bios setup
if changes is not saved then change cmos battery
Jun 14, 2008 | Toshiba Portege R100 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
