Question about NetGear NeoTV Max Streaming Player
Connecting timeout internet connections takes to long and then it says connecting timeout
What does network connection terminated due to abort or timeout mean?
It means either your internet connection or Yahoos network was stopped because it was taking too long to connect.
It could be your cable company that is slow or on that day something was wrong with Yahoo's network due to overload or too many users.
Jul 22, 2014 | Yahoo Computers & Internet
N600 error 651
This is not a router, it is a range extender. It does not work without a router connected to the internet.
651 is just a timeout, as it cannot get an internet connection.
Look at the router and find out why the range extender does not work.
Does the router work on the internet, try wirelessly and by directly connecting a cable into the LAN port.
Mar 12, 2014 | NetGear Computers & Internet
When ever i go on the internet and I wrtie google or youtube on it. It says web connection timeout
1. is it isolated on these two websites? have you tried to access other sites with no problems (no connection timeouts)
2. make sure that the you have a strong signal, (if you are using gprs/edge) if you are using wi-fi, make sure that you have a strong connection (check your signal indicator 3 or 4 bars are good) then try to connect to these sites again
you may also want to refresh your phone: turn off, remove battery and sim, wait for a few seconds then turn it on, then do step 2
Apr 14, 2011 | Nokia E63 Cell Phone
Why cant i watch anything on youtube. it will not work at all.....it says time out.
Webpages timeout with an extensive display of resources. First, the factors that predict website network displays are structures that computers are built. For example, dial up telephone line internet structures are least multimedia compartible. Once requested media that least displays initiatially timesout as notification of incapability. Second, the timeout conditons occurs with requesting resources from another device that least has the capacity to produce. A computer network provides notification as timeout saving integrity of surfer. Third, timeout is encouted in conditons that network malfunctions were experienced. In such a situation either as the device structures have least compartible conditions or another devices is encountering situations least producing results. Solving website timeout conditions. First, restablish the network also called refreshing either connection or websites or pages. Second, in a situation that an observable malfunction were encounted requires repairs to take effect.
Feb 25, 2011 | YouTube Computers & Internet
Computer repair tech said Linskey wireless caused internet prob
If you are using DSL as your internet connection there is a timeout period that could be setup in the linksys.
In order to change this you need to log into your router and on check on the setup page. You see the timeout option.
Check with your linksys manual for detailed instructions for logging into the unit. If you dont have it, you can always get it from their website.
Jul 31, 2009 | Linksys Wireless-G Broadband Router
Can't turn off idle time out. and have to keep rebooding the router
Idle timeout is configured with the command
exec-timeout 0 0
The value is in minutes and seconds. If you put in a value of 0 1 then it will time out after 1 second of time. Idle time is configured separately for console and vty connections. One option is to connect via the console port and then change the idle timeout on the vty connections. If you have no access to the console port then you have to type fast or paste the proper commands in. You can type out the following commands into a text editor
config t
line vty 0 4
exec-timeout 5 0
end
You would want to copy them into your clipboad before logging into the router. Once you get logged in and into enable mode, you can paste the clipboard into the terminal (check your terminal instructions to find out how). This should set your idle timeout value to 5 minutes.
Jul 01, 2009 | Computers & Internet
Internet does not work
dialup is becoming a thing of the past, most webservers are optimized for broadband use.
It is possible that the sites you are trying to reach are simply timing out the connection because the dialup connection is just too slow. Alot of servers have a timeout period and the 56k connection might be taking longer so the webserver cancels the connection.
Apr 20, 2009 | IBM ThinkPad R51 Notebook
Need help with my ps3
this means your ps3 is not connected to the internet and when the ps3 takes to long to connect this is the messages you see time out try to use an Ethernet cable instead of wireless
Mar 13, 2009 | Sony Playstation 3 (PS3) Console
Centrios internet radio gives dhcp timeout
This is likely because out of the box, the firmware for this unit doesn't support WPA2 and even certain variants of WPA. I recommend: configure router for WEP or even open (i.e. unencrypted) connection, connect unit, go to setup/update firmware and let it update from network, power cycle, reconfigure your router for WPA or WPA2 security, attempt to reconnect unit to wifi. The updated firmware supports more formats and may allow your new router's config to work. You can also try doing the firmware update over the wired LAN port. Hope this helps.
Sep 27, 2008 | Computers & Internet
I have problems to connect my LG KG800 WITH THW PC
same thing is hapenning with my phone LG RUMOR
when ever I am trying to connect internet it says NETWORK TIMEOUT ERROR 7 ...
any IDEA ???
Jan 12, 2008 | LG KG800 Cellular Phone
NetGear NeoTV Max Streaming Player Logo
63 people viewed this question
Top NetGear Televison & Video Experts
David Payne
David Payne
ray gallant
Dave
Dave
Level 1 Expert
Are you a NetGear Televison and Video Expert? Answer questions, earn points and help others
