Question about Campbell Hausfeld Air Tools & Compressors
Paint gun manual - Campbell Hausfeld Air Tools & Compressors
May I have the manual for a WAGNER PAINT SMART electrical spray gun. thank you
nozzle head might be shut try turning it to open, you should here air coming out if air comes out but no paint comes out then paint is to thick and might need thinning, hope it helps.
May 20, 2014 | Wagner Spray Tech Air Tools & Compressors
Paint gun splatters paint on car
The needle valve in the spray head needs to be cleaned or replaced.
Nov 21, 2013 | Binks Paint Spray Gun Repair/rebuild Kit...
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
May 22, 2010 | Campbell Hausfeld Air Comp Basic Spray Gun...
I need an owners manual for a Mastergrip paint sprayer. It is a 10-pc set and I got it without any instructions. Does anyone know how I can get an instruction manual or owners manual?
I have a Mastergrip HVLP Paint gun set up with the manual. If you would like me to copy it for you, I will. I can also answer questions for you. Ken
May 07, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
