Question about iHome 3-Port USB 2.0 Hub and 55 in 1 Card Reader
Ihome card reader - iHome 3-Port USB 2.0 Hub and 55 in 1 Card Reader
Tip
How to connect an my iPod Nano 3rd Generation to an iHome
<p>Your iPod nano to a device like the iHome to boost output audio or video to a TV in your memory. The iHome also charge your phone as it is docked. You need to take steps to ensure that your iPod will be able to successfully dock the iHome. Once your iPod is well prepared, so you get the most out of your drive for iHome. <br /> <p><br /> <p>1. Connect your iPod to your computer and launch iTunes. <br /> <p><br /> <p>2. Click "Help" from within iTunes, click "Check for Updates". <br /> <p><br /> <p>3. Select "Yes" when asked if you want to download and install updates. If no updates are available, disconnect the iPod. <br /> <p><br /> <p>4. IHome Connect your unit to an AC outlet. <br /> <p><br /> <p>5. Remove the protective layer of your iPod Nano, if applicable. <br /> <p><br /> <p>6. Let the iPod Nano in the dock with the front facing you. You will feel it snap into place. <br />
on Jul 21, 2011 | Computers & Internet
My ihome want charge my iphone 4
Your iHome may be an older model with an the wrong charge type. Different iPhone / iPod generations use different charge voltage with iPhone requiring a higher voltage than your iHome gives. My suggestion would be to get an adapter that should fix the problem.
Jun 02, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
Hi I have an iHome alarm clock/radio that has an ejectable outlet for the iPhone/iPod/ etc and after one drop to the floor, the piece that reads iHome broke off and the ejecting piece does not push out by...
sadly this devices are no longer sold
you should try to find a damaged iHome and use for replacements or find a used one to replace your actual device
ihave an iHome too, and i had made some tricks to keep it working
Mar 22, 2011 | Audio Players & Recorders
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
I need a driver for my webcam ihome IH-W313NR ? I
Instruction manual
http://www.life-works.com/product_files/iHome%20MyLife%20Webcam.pdf
Ihome - Mylife drivers
http://www.ihomecomputer.com/404.asp?404;http://www.life-works.com:80/drivers
Sep 15, 2010 | Computers & Internet
I want to play a Zen V on an ihome (portable speakers)
there is a double jack wire that should have come with your ihome plug one end ito your zen head phone hole and the other end in the back of your i home thats how mine works idk about yours but it should work the same for all ihomes
Nov 01, 2009 | Creative Labs Zen V MP3 Player
Problem with ihome and ipod nano.
yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
http://www.ihomeaudio.com/products.asp?product_id=10186
Dec 25, 2008 | Apple iPod nano
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
iHome 3-Port USB 2.0 Hub and 55 in 1 Card Reader Logo
57 people viewed this question
Top iHome Computers & Internet Experts
Elise Lacoursiere
Elise Lacoursiere
Chris Benedict
Level 1 Expert
Are you an iHome Computer and Internet Expert? Answer questions, earn points and help others
