Question about Acer S243HL 24 inch Monitor
No signal ACER S243HLBMII - Acer S243HL 24 inch Monitor
Now on a acer tablet
Strong is relative to your position and where the signal is coming from. If you don't have a wireless router in your location then the signal has to go through walls etc. either way it is not your wireless signal from what I gather from your post.
Apr 10, 2015 | Acer Tablets & eReaders
Acer Monitor V193W has no signal
There are 2 basic reasons for the "No Signal" message.
  1. Loose video card inside the machine- if you're machine didn't come with on board video or if you are using an independent video card instead of on board video, the card can unseat at times, either due to movement of the machine or pulling on the video cord
  2. Loose connection between the video cord and/or monitor and/or machine. Unless the plugs on both ends are secure (including tightening both screws to prevent loss of connection), the cord can dislodge just enough to interrupt your connection, causing a "No Signal".
If neither of these is the case, try hooking up a different monitor (if equipped, you can use an HDMI cable to your TV) to see if the "No Signal" message persists.If using a different monitor works, the issue is your Acer Monitor.
Dec 07, 2011 | Acer Computers & Internet
I have an Alba tv and a acer laptop. I bought a 15 pin VGA cable and connected it to my tv but it is just saying no signal on the tv, can you help?
Since you have a Cable , I supposed you did pluged it in... one side in the Input of your TV and the other side in the VGA connector on the side of your ACER,
Once this is done you have to press and Hold the FN Key of your Acer and press the F5 keyA menu will display 4 icons an icon of your ACER, your ACER and a monitor, a monitor only and an icon of a projector.
press F5 Twice and the signal will show on Both your Acer and to the TV
Tree time will send the signal to the TV only Five times and you will return to the Icon list on your ACER
Jul 25, 2011 | Acer Aspire One PC Notebook
Can i connect speakers to this and how
Hello there,
Yes you can on the side of the unit on the base is a green jack that is used for headphones or speakers i hope this was helpful don't forget to rate
Jan 26, 2011 | Acer S243HLbmii Widescreen LCD Monitor 24...
I have no audio out. Buy my S243HLBMII monitor have a speaker and an audio input. audio input is only enable while I connect the lcd with vga cable. I want to disable the audio in and want to make it audio...
Hi lucasthehack,
I would like to help regarding your concern about the Audio issue you are experiencing with your LCD monitor using HDMI.
Since you are using HDMI you really do not need to look for an audio out to get sounds out of your LCD monitor.
- On your screen you will see a speaker Icon wherethe time is, right click on the speaker Icon then select Playback Devices.
- In the Playback Device Window you will see HDMI on the top of the list right click on it and click set as default, this will give you aduio out from the HDMI connection.
Restart you system with the HDMI conencted to the LCD monitor this should make the changes we made work using HDMI video and audio on your LCD monitor.
Thank you for choosing Fixya,
avf110686
Dec 21, 2010 | Acer S243HLbmii Widescreen LCD Monitor 24...
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
I am trying to connect my acer PC to a tv but get
The inputs on a TV are normally via the ariel and go into a pre-amp
To get a signal in you, would again, normally connect to the RGB or Video in which bypasses the pre-amp.
The VGA cable will be outputting a digital signal which a monitor will understand but a TV will not as it prime supply is via an analog signal
You may be able to get a connection if you process the signal through a freeview box which changes the signal from analog to digital
Jul 01, 2009 | Acer Aspire 5102WLMi Notebook
No signal or loses signal from computer
Keep the computer on when you plug it it
so have the computer ready
May 12, 2009 | Acer PD725P DLP Projector
I have a ACER TRAVEL-MATE 800LCI...with wi-fi wireless...sometimes the wireless works some times it doesnt...what kind of router or what ever will help me get a stronger signal from my house...please help...
put up the high level things then you get it very stronger signal now you not get be'coz of the signal low strenght is not there so he can't caught the signal so pls change it in the high level
Feb 22, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
Acer S243HL 24 inch Monitor Logo
29 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
