Question about HP L1702 17" LCD Monitor
HP 1702 Case Removal
How do you get into an HP 1702 LCD monitor.
I have removed all visible screws and pryed at the case a little but it seems unwilling to open.
Don't want to risk forcing it.
Thanks in advance
  • 78 Answers
  • 112 Answers
Keep prying. Plastic clips are strong. You won't break it, maybe a clip or 2. LCD is in a steel case inside. The outside plastic is only for looks.
Posted on Mar 17, 2009
  • Rob Crowther Oct 26, 2010
    After taking out the two screws holding the stand , remove it followed by the two screws in the bottom corners. Pry the case apart from the bottom as it has plastic tabs into slots at the top. Then remove three screws that hold the cable mounting plate. Pull off the power pair cable connector and carefully prize/pull off the data connector and two earth screws. The cable mounting plate can now be removed. At this stage you can get to the two circuit boards.
With the stand removed (two screws) and the two bottom corner screws removed pry the case open from the bottom corners as it is on tabs in slots at the top.
Once inside remove the power connector and carefully prize/pull off the data connector.
Remove three screws holding the cable mounting plate and two earth screws. Remove the data cable from under the control cable and the whole cable unit comes away revealing the two circuit boards.
Posted on Oct 26, 2010
I have a viewsonic vx1940w Monitor which will no longer power on. I'd like to take the back off and see if there are any loose connections but there are no visible screws. Does anyone know how to open it?
There is no exact instruction, but first thing you have to do is to remove the stand, then starting at the bottom edge of the case using thin flat blade screw driver to pry open the case up and then work your way around the case, you can also look at YOUTUBE, just search for 'how to repair LCD monitor', 'How to open LCD monitor'
Bad caps (leaking/bulging top) are common failures.
http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | ViewSonic VX1940w LCD Monitor
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
How to remove outer case on Pl926wbi
Remove the four bezel screws on the bottom edge of the monitor. Gently pry up where you removed the screws and slide the bezel off towards the top of the monitor. The six mounting screws for the lcd panel will be visible. Remove them and inplug the lcd cables and set it aside. You now have access to the main circuits.
Apr 11, 2009 | Proview PL926WBi 19" LCD Monitor
How do Iopen the case of an HPvs17x monitor?
The Capacitors on the power board are usually the reason for failure of an LCD. If you open the HP VS17 ( I can provide an exhaustive step by step If I have to) remove the five screws for the power board ( larger of the two boards) and look for an area where there are 4 caps (see pic). Look for exploded, popped up, bulging, or leaking caps and replace with the same or slightly higher tolerances. The one I replaced last night were (2x )1000uf25-50volt and (2x) 470uf25-50volt. Check the rest of the board for similar issues and replace as needed.
Jan 21, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Dell 2001 fp back panel removal ?
First remove the four screws behind the stand mount on the monitor. Then turn monitor vertically so thet the bottom is up. Next look for slots betweem the portions of the srame on the bottom. Use a slotted screw driver to pry open the bottom. Becareful to not damage the plastic. As bottom is opening pry around the entire frame it will come loose. Make sure you place the monitor on a table covered with a towel in the final process to un clip the case.
Herm Hart
Jan 10, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Lg monitor l194wt
It's not glued!!!! It's clipped together...and DON'T take out the screws first...
First, turn the monitor upside down and look at its thin edge. See where the grey bezel meets the black case? That's your clip point, all the way around the monitor. The reason you want to start here? This monitor is VERY tight, and there's a good chance you will mar the plastic, so it might as well be in the least visible place.
Next, fit a plastic trim removal tool (you have one of those, right? Right!? :) ) in between the black and grey plastic, halfway along the length of the monitor. If you have difficulty getting it in, run it back and forth until you find a loose point, but you'll eventually have to come back to the tight spot.
Here, there's a little bit of finesse required...you have to pry the grey part (which I will start calling the "bezel") gently upward, not away from the black plastic (which I will call the "case"), perpendicular to it. This will pull a clip up out of its slot. When you feel the clip release, now you can move it slightly away from the case, but don't remove the trim tool. Keep unclipping the rest of that side.
Once you've gotten the hang of it, do the next side. This bezel is particularly tight, so don't start at the edge...you will definitely damage it. Once you've gotten two sides loose, the whole job becomes easier, but still stay patient and careful, because there's a lot of potential for damage.
Now that you've gotten the entire bezel off (and the hard part is over with), hold the LCD in place as you turn the assembly face down onto a soft cloth, like a blanket or comforter. Now you can remove the four screws from the back.
Lift the case off and remove the two screws holding the switch assembly. This will lift off easily.
Lastly, partially remove the silver tape holding the electronics case on the back, carefully remove the connectors (remembering their positions, of course), and you're ready to play electronic doctor. I'm posting this with my newly repaired L194WT. :)
Jun 14, 2008 | Gateway FPD2275W LCD Monitor
LCD screen removal & assembly
If you can post the image of your monitor here, it would be great. Actually, I used to repair monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off.
Thank you,
Mar 18, 2008 | Computers & Internet
Dell 1704FPTt 17" TFT LCD Flat
I used to repair LCD monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Mar 02, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Screen blacking out.
Hi, I used to fix a monitor from Dell. There are 4 screws at the back of rear panel and no screw at front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off.
For the metal plate that shields the back of the screen, There are some screws you have to deal with. Those screws are at the power and screen connectors.
Thank you,
Tan
Mar 01, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
HOW TO OPEN cASE
After you remove the stand, there is a metal plate under it which will come out. Underneath that there is one more screw, (the last one). After that, carefully pry the case apart.
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
HP L1702 17" LCD Monitor Logo
777 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
