Question about Vizio P50HDTV20A 50 in. Plasma HDTV
I have a Vizio 50" Plasma VP50HDTV20A and the picture has gone out. I only receive sound. Some one told me that I needed to replace the picture board. If so , where can I buy one and How do I install it? How much do they cost? Thank you!
  • jeff534 Mar 12, 2009
    I did check all of the cables and also used another TV to veriry the incoming signal. It is definately inside the TV. Thanks!
    Yes
  • 362 Answers
Hi jeff534,
A plasma tv has many components that could cause the issue, it very well could be the video board but without doing some voltage checks from the power supply out it is almost impossible to diagnose here. Please post back with all symptoms and any troubleshooting you have done so far.
Does the screen light up to a gray screen or is it completely dark? Have you tried connecting your video source to different inputs? Do you have electronics repair experience? Do you feel with a Service Manual and guidance from a FixYa expert could you perform voltage checks safely?
Please post back with your findings and we will begin further troubleshooting.
Lone99star
Posted on Mar 12, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Most replacement parts for Visio units are available from http://web.shopjimmy.com/. Pls start here.
Good luck and thank you for using FixYa.
  • 203 Answers
It could be any one of the following problems : X or Y sustain board, bad screen (PDP panel), logic board,buffer boards.
it could be a big problem for someone with no plasma experience. you should take it to a service centre.
    Brigadier General:
  • 3,614 Answers
have you first check any possible loose connection from your unit.
check first the wiring.
  • micromaster
    micromaster Mar 12, 2009
    have you already contacted a service man for that?
  • micromaster
    find part HERE
Vizio 50" Plasma VP50HDTV20A comes on with sound but screen shows rainbow colours before pictures comes and picture is blurry when on and not in full color. All the inputs have the same display.
If this is an old Plasma TV that you picked up somewhere, it may just be too old. Plasma screens degrade over time.
New plasma TV's are not common anymore, so I am assuming this one has been around for awile.
If it is new, take it back to where you bought it.
Apr 10, 2017 | Vizio Computers & Internet
I have a vizio model vp50hdtv20a the picture is slow to come on like it needs to warm up and i have no sound any suggestions to what the problem might be?
Could be the Tcons flex cable connections. If that doesnt solve it then the Tcon would be suspect. If you need a Tcon you can get one from www.tvrepairworld.com
Nov 04, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have vp50HDTV20A HDTV PLASMA TELEVISION The
Good day sir Thor!!!!
I already encounter that kind of problem many times..It looks like all normal even the green power light is not blinks or change to red or amber color but still no sounds or picture on TV..
Sometimes it will happen to plasma TV in all brands and model..It cause of faulty main board..
This is the sample picture of main board of your unit..Part # (3850-0142-0150)
You can order this parts here:
http://premiertvparts.com/index.php?main_page=product_info&cPath=1&products_id=797
http://www.ebay.com/itm/NEW-VIZIO-VP50-HDTV20A-MAIN-UNIT-3850-0142-0150-2A-/320737894046
http://tvpartsfast.ecrater.com/p/12695612/vizio-3850-0142-0150-main-board-for-vp50hdtv20a
http://modulesrus.ecrater.com/p/11497716/vizio-main-a-v-3850-0142-0150
Just replace the board to fix your TV and it works again..
Note: When you install the board make it sure that the static energy on your body discharge to ground to avoid corrupt of main board IC..
EXAMPLE: open the cover then find the main board..before you do that make it sure you hold the metal portion of your TV to discharge static after that you can now freely replace the board and also make it sure to memorized the connector to avoid damage to make it sure take a picture on it before unplug connector for future reference in case..
again discharge static please!!!..Only few tech or other people know this that's why when they install new boards its not works even it is new..I discover this base on my experience and study..
Hope it helps..
Please don't forget to rate!!!!
Thank you using fixya..
Feb 28, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a vizio model # VP50HDTV20A I have sound but no picture and checked all the fuses on the power supply board and the Y SAUSTAIN BOARD all ckecked good caps look okay.
more then likely you have a bad sustainer board. Do you light coming from the panel. Sometimes theres an IC chip under the heatsinks and that goes bad causing the screen to go blank. Let me know if that helps at all.
Sep 22, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a Vizio P50 HDTV20A Plasma TV. I have picture but No Sound. I have plugged audio into all the inputs on the back of the TV. I don't get sound. I have gone into the menu and made sure the speakers...
have the same tv and fixed my no picture problem and now have no sound. I'm going to replace the sound board part #0171-2871-0163 hoping it will do the trick. Good luck
Aug 09, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have the same tv and fixed my no picture problem and now have no sound. I'm going to replace the sound board part #0171-2871-0163 hoping it will do the trick. Good luck
Aug 09, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
50' Plasma won't turn on. No power.
hi, i have the same unit and did the same as yours i open it up and it had a blown fuse on the main board there four fuses. mines had ones of the two fuses on the right lower corner of the main board blown out i replaced it and worked fine again.
Apr 19, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio vp50hdtv20a won't turn on.
The power supply is the culprit.. Check out my video that explains everything..
http://www.youtube.com/watch?v=v_oL1i6VOGM
Jan 05, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Vizio P50HDTV20A 50 in. Plasma HDTV Logo
378 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
