Question about Samsung RS267TDRS - 26 cu. ft. Side by Side Refrigerator - Stainless S
Error code OF appears
Works fine does this every so often. I have gotten it to reset but this time it will not
Error code 0F
Good Morning Stephanie Garcia, thank you for your post!
From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
Jan 17, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Freezers
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
FF 6 code
What is the model number?This error code FF indicates a problem with the main control board. When the power cord is disconnected for 30 seconds and then reconnected, it resets the board. Sometimes this procedure corrects the problem and sometimes it does, for only a short period of time. Usually in this case, the main board will need to be replaced.
Nov 10, 2012 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Freezer lffu14f54hwc try to cutoff by holding down till 0 appears get e7 appearing
Hello Oran - Typically error code F7 on Frigidaire freezer indicates that the unit has detected a stuck key or fail safe mode initiated. Check if it has a thermistor failure and may possibly need to replace the main control board. Contact a professional to move forward accurately.
Oct 12, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have an error code on my upright frigidaire freezer "CE". it holds the temp but this error code keeps flashing. how can I get rid of it?
I just unplugged mine and plugged it back in. It works fine now. The problem happened after a quick power outage.
Jul 29, 2010 | Frigidaire Freezers
Error code on display "CE". Does this also mean the unit if not freezing while the error appears?
maybe theres a defect in the board causing the error or the compressor bis defective
Jun 21, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Upright Freezer
Check that the back light is not on all the time as this can.
Thanks J
Jan 17, 2008 | Freezers
Samsung RS267TDRS - 26 cu. ft. Side by Side Refrigerator - Stainless S Logo
29 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
