Question about Honda Garden
Adjust psi on proforce model number wp-2402-swhb
How do you adjust psi
2 Suggested Answers
  • 68 Answers
SOURCE: For pressure washer Model WP-2402-SWHB,
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Posted on Feb 08, 2010
Pump comes on at 30psi and off at 42 psi. Is there a way to adjust the lower set pressure so it will come on at say 22 psi? Goulds model c48a93a06
Most pump pressure switches have adjustment screws or springs with adjustment nuts on them. Usually there are two. One to adjust the on pressure and one to adjust the differential that is the pressure dideference between off and on usually about 20 psi
when you remove the cover look inside the cover there is usually a diagram identifying the adjustment screws or nuts. Hope this helps
Bob
Nov 04, 2014 | Plumbing
ProForce PWC102350 2,350 PSI 2.3 GPM 163CC MagnaForce Gas Powered Pressure Washer will not start
If you have compression then the first thing you check is for spark. If you have spark then you move on to the fuel system. You will have to pull off hoses at a couple of points to see if gas is at the carb and further along. If it is the carb then a simple carb kit will work.
Apr 13, 2014 | ProForce PWC102350 2,350 PSI 2.3 GPM 163CC...
Proteam proforce 1500xp machine won't start?
Check the fuse or the or the wire, could be broken
Mar 28, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
Regulator outlet pressure too high ondd55146 type2
The pressure switch needs it's cut off pressure adjusted.
Feb 23, 2013 | Air Tools & Compressors
Porter Cable pancake rated at 150 PSI stops at 135 PSI. It has done this since it was new.
If it's pumping up to 135 psi, shutting off and then restarts at the same pressure point since it was new, the pressure switch may have been set low at the factory. I don't know which model you have but most pressure switches have directions inside their cover as to how to adjust the cut-out and cut-in pressures. Be careful doing this, overpressuring the tank is dangerous. There is an adjustment screw or bolt that changes the pressure on the switch spring. Some pressure switches have two screws, one for cut-in and one for cut-out pressure. A few have one that adjust both pressures. If you do adjust the cut-in/cut-out levels, do it slowly and cycle the motor a couple times between each adjustment to see where it turns off and on. If the compressor is doing what you want it to, only pumping to 135 psi, it will live longer than if you adjust it up to 150 psi. Those last 15 psi of air are hard to get and will mean the motor will be running longer and more heat will be building up in the head.
Oct 01, 2012 | Porter Cable Air Tools & Compressors
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I bought it new about 2 yrs ago? What needs to be done with this problem? I noticed on this...
Hello;
150 is your cutout pressure. It's the factory setting and is not a problem. But, It appears you have a pop off (safety) that is set for 125 psi, So, If you want 150 psi, the pop off needs to be adjusted. If you want 125 the the cut out switch needs the adjusting. The setting. More than likely the 125 psi pop off valve is correct and the switch needs to be adjusted down below the pop off pressure. To sdjust the switch, remove the cover of the box the cord comes out of.Adjust using the screw(s). There should be one for cut in and another for cutout pressuressures. The cut in pressure should be 90 psi and the cutout should be at 125 psi.If the pop off valve blows off at 125, It needs either replace or adjusting. It's best to replace it.since the spring inside has lost tension. You will be constantly adjusting it otherwise. Good Luck -Ned_ Take caution not to get your tool or fingers into the electrical in the switch box.
Apr 15, 2011 | Dewalt & 2HP Hand Carry Heavy Duty...
I have moved in to new flat and the washing machine is bosch WVF 2402 I need a user Manual if its possible please. regards, Maral
Sorry but this forum does not supply manuals direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and helping for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 28, 2011 | Bosch Classixx WVF 2402 Front Load...
Can I limit the pressure to 120 PSI, the upper recommended limit for my nail gun?
adjust your pressure switch on your compressor .remove the cap and turn the screw clockwise to increase and counterclockwise decrease.turn the screw counterclockwise a bit and release some air till the compressor start pumping.then just before to reach 120 psi turn counterclockwise to stop the compressor at 120.then release some air again till it cuts in again and look at what pressure it will stop.keep going that way till you get your 120 psi.cut in should be around 90 psi(30 psi differential)depending what kind of pump you have (if the pump can handle 150 psi )you can adjust it to cut in at 120 and cut off at 150 and install a pressure regulator adjusted to 115 to 120 and get a nice steady pressure going to your nail gun.(the best way to do it!!!)
Jan 17, 2011 | Air Tools & Compressors
Delta 2402 two handle spout drips but stops when cold water is cut off from below. Assembly two years olf and top two washers look fine. What next?
could be dirt in cartridge.Could be the limit adjuster in the handle.I'd take the handle off and manually shut it off.But probably dirt or debris in cartridge
Jun 21, 2010 | Delta 2402 Classic Two Handle Kitchen...
Garden Logo
83 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
