Join finisher to copier
SOURCE: FINISHER PROBLEMS
firstly you have to check what teh copier is set on i.e tray1 or tray2 , select one of the trays,and try to print this should work if , otherwise place the paper on bypass tray right hand side try this, somtimes the sensors are displaced which detect paper, try this and let me know.
SOURCE: toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
SOURCE: Copier Studio 55 Copier.
Hi how are you this is jack
Dear ,
you copier e-studio 65 showing message dispose of used toner.. ok.. Its donot mean dispose all old toner and install new toner... Its mean dispose used toner box... Dispose toner Box is a seprat box copier all garbage toner droped this box and when this box are full then copier showing message please dispose used toner box... please check it and dispose it.
Thanks
SOURCE: manual for Toshiba COPIERS - E-STUDIO 211C Copier
for a speedy solution try to contact and for further information regarding Toshiba Copy Centres go towww.toshibacopycentres.co.uk or contact us on 01932 580192 or [email protected]
if anything they should sort you out!
