Question about Lifetime 1221 Pro Court 44" Portable Basketball System
Replacement base for spaulding 66291T - Lifetime 1221 Pro Court 44" Portable Basketball System
I cant log in! running short of med.
Hallo, Ms Spaulding,
You're posting in Fixya, which is a forum for repairing cars, computers, white goods and so forth.
I suggest you look up your doctor's surgery and see if you can find an email address for them and contact them if your prescription medicines are running low. I'm afraid I'm writing from the UK and if procedures differ where you are, please excuse me.
Mar 09, 2015 | Cell Phones
I have a constant beeping on my jabra headset gn 9350
headset not syn'd with base, replace headset in base and remove power from base
count to 10 re-power base allow set up to complete, green lights across base and blue battery light on ear piece, allow to charge if less than two green lights on base.
if this still does not work slide ear piece apart count to 3 and silde back together again replace in base and allow to light up again, it will now work
Jul 18, 2014 | Jabra GN9350e Wireless Headset
Should Spaulding 44" #77537T be filled with water or sand?
what is this a weight or whatever? I would use sand as water thoughok will freeze and bust the plastic shell..
Oct 27, 2013 | Pool & Spa
Should Spaulding 44" model # 77537T be filled with water or sand?
Hi, according to Amazon (see link below), that model can be filled with either water or sand. My only thought was that water would be much easier to remove than sand if you ever wanted to empty out the tank.
http://www.amazon.com/Spalding-77351-Portable-Basketball-System/dp/B0027HDIAI
Oct 26, 2013 | Lifetime 3819 Impact 44" Basketball...
How often do I need to replace me bed's base?
I advise you to replace both the base of your bed and your mattress at the exact same time. A base with inadequate support will cause a new mattress to dip in the center within weeks.
Aug 20, 2012 | Furniture
2006 ford fusion with 95k on it, would i need to replace the (pc valve) any time soon? thanks, T. Spaulding
Since you have high miles and if it is the original and being inexpensive I would recommend that it be replaced.This could also help with performance of the car.
May 10, 2011 | Ford Fusion Cars & Trucks
Got the basketball poles stuck together and theyre not aligned
Dropping the stuck poles definitely WORKS! We had stuck basketball poles from a Spaulding 54 inch together wrongly. Dropped them on grass from shoulder height 4 times and they loosened enough to pull apart.
May 01, 2011 | Lifetime 3819 Impact 44" Basketball...
My complaint is about the go diego go toy trike, the screws that hold the handle bars to gather will not stay in ,, the holes are either to big or the screws are to small. do hope to hear answer on this...
1. You can buy a bigger bolt at a hardware store with a nut that fits the bolt and use a washer on both sides of the handle bar. Also, before screwing on the bolt, put teflon tape around the bolt screw where the nut is to go. This should secure the nut from unwinding through use. Make sure the nut is on more than hand tight.
2. If you cannot purchase another bolt, then start with washers and teflon tape. Be sure to tighten the nut more than hand tight using a wrench or pair of pliers.
Mar 07, 2011 | Cycling
Lifetime 1221 Pro Court 44" Portable Basketball System Logo
71 people viewed this question
Top Lifetime Sport & Outdoor - Others Experts
Vernon Taylor
michael vanier
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
