Question about Nikon N6006 35mm SLR Camera
No film in but it says there is
The other day I was shooting with my N6006 but it only went to 16 shots and then wouldnt go any further. So I took the film out and now it still says its at 16 exposures even though there is no film in it
    Sergeant:
  • 435 Answers
Needs repairing at a qualified shop
sounds like the film advance motor died
Posted on Feb 13, 2015
5 Suggested Answers
ice man
  • 68 Answers
SOURCE: Premature Film Rewinding
the only thing that I could think of when I read your situation is, that you might not be using a DX coated films. see, the camera reads the bar code on the film and maybe it is not the same program. check the camear manual and make sure you are using the same kind of the suggested film in the manual. good luck
Posted on Apr 13, 2007
  • 362 Answers
SOURCE: Film speed override?
Press and hold the ISO button on the top left and rotate the command dial on the right until the film speed appears on the display. Release the ISO button and the speed is set.
In case your instructor hasn't told you, IR light is just below visible light on the spectrum and has a longer wavelength. Therefore, IR light will focus behind the film plane for a given setting. I.e., if you preset the lens to focus at 10 feet, the IR light will focus at a shorter distance. Unless your lens has a distance mark for IR, I would limit my shooting to longer distances and smaller f-stops to use the depth-of -field to compensate. When you are in focus for IR, the image in your viewfinder will be out of focus. The closer you are to the subject, the more out of focus the image will appear at the correct focus setting.
Posted on Nov 28, 2008
  • 185 Answers
SOURCE: Blank Film Developing
kwilson36
you should have at least 6in. of exposed film from the film canister to the take-up spool unless you loaded the film in total darkness.
open the back cover to make sure the shutter is working, reload and give it another try.
Posted on Jan 30, 2009
  • 20 Answers
SOURCE: location of rewind pin for nikon n6006 film camera
There is a safety switch to prevent accidental operation.  Hold the camera like you are taking a photo.  Rotate the camera down so the lense is pointing towards the floor and you are now looking at the bottom of the camera.  On the right is a small button.  In the middle is a slide switch with an arrow pointing to the left.  You need to hold in the button on the right while sliding the switch to the left.
Posted on Feb 05, 2009
Having a problem loading my nikon n6006
You may download a copy of the manual from here. The film loading instructions begin on page 13.
Jul 14, 2012 | Nikon N6006 35mm SLR Camera
I have trouble taking indoor (low light) photos. pictures come out blury and the camera does not snap the picture properly i have a nikon 35 mm n6006 camera
Hi Rebecca--
The hardest thing about low light photography is balancing your available shutter speed to the amount of action you're trying to capture.
Here are a few things to try:
1) Try using a tripod. Steadying your camera during long exposures will greatly improve your image clarity.
2) Buy a faster film. You may need to increase your film's ISO setting. Try 400 to start, then go up from there. Remember, faster film always produces grainy images, and it usually costs a little more to process. If you're stuck with 100 ISO, you can always "push process" the film, where a given ISO is let to sit in its developer longer than usual--This will cost you more too!
3) Invest in a good flash system. Nikon has tons of hotshoe flash systems that rarely compromise the ambient light-mood of a given situation. Look for one that lets you aim the flash in different directions, and try to find one that will meter a light situation on its own.
4) Turn on the lights. If you're ok with losing some of the romance of an image, turn on some more lights to give you some more flexibility when making your exposure choices.
5) Open up your aperture. You may find that a lot less in depth of field will give you a lot more in image clarity and exposure flexibility. Shooting at f2.8 with only a birthday cake lighting your subject will grant you many more valuable shutter stops that shooting the same with f5.6.
Remember, Rebecca, if you're shooting handheld, you must do everything in your power to shoot with the quickest shutter speed available. This will cut down on the blurriness of your indoor images.
--Hope this helps.
Oct 06, 2010 | Nikon N6006 35mm SLR Camera
Error .press shutter release button again
did a shoot on friday and came home and downloaded all the pics and then I went to do a shoot today and my camera wouldnt work. When you go to take a shot the shutter closes and then and error comes up and says press shutter button again to release. This opens the shutter back up. The picture it takes is only the bottom half of the object you are shooting....any ideas of what I can do to fix this? I have only had my camera 30 days so I have no clue what it could be.
Jul 29, 2010 | Cameras
Can't close door after loading film.
sounds like the door latch broke. (tape) Canon will only replace/upgrade not repair.
ours cracked after a drop then broke replacing the film.
Jan 07, 2009 | Canon Sure Shot Z155 Caption 35mm Point...
Camera froze up Type Canon Sure Shot ZOOM-S
Sounds like the film either didn't advance thru the camera or its been rewound.
Here's a copy of the user manual:
http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Dec 25, 2008 | Canon Sure Shot 105 Zoom S 35mm Point and...
Evoca 115 stopped working after 22 shots
I think you have run out of film. 22 panoramic shots is the equivalent of at least 35 regular shots. Did you open the camera in a darkroom because if not you might of ruined the film. You need to try rewinding the film putting in a fresh roll and I think it should work. Hope this Helps.
Nov 22, 2008 | Samsung Evoca 115 35mm Point and Shoot...
Sep 07, 2008 | Nikon N6006 35mm SLR Camera
Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 06, 2008 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
Nikon N6006 35mm SLR Camera Logo
63 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
