Kenmore 20692 top load washer won't spin. The
Kenmore 20692 top load washer won't spin. The rest of the cycle is fine and I can hear the motor running (not taxed sounding) when the spin cycle is on. The barrel is almost completely empty of water so I think it broke down towards the end of the last use. What can I look at myself?
  • 478 Answers
This is most likely a motor coupling. Pull washer towards you about two feet tilt back, look at floor for black sute. The coupling is attached to the motor to the transmission. It cost about 15.00 and takes a novice less than an hour. There are two 1/4 inch srews, one on top one on bottom , remove these use a scwrew driver to pop off the clips,pry off coupling on both side and replace.
Posted on Mar 12, 2009
Why does my kenmore washer 110 fill with water but won't wash or spin?
Do you happen to hear a humming noise coming from the machine after the tub fills? This might indicate that the motor is spinning, but the belt that connects the motor to the rest of the machine works is broken. It is located underneath the washer. Tip the washer a bit and have a look. If it's broken, you'll probably find the belt laying on the floor. Take that to an appliance parts store where they can match it up with a new one. Installation is not too difficult. The belt will go around the motor pulley, the transmission pulley, the water pump, and in some cases, a spring-loaded tensioner. I hope this helps! :) -Jason
May 06, 2014 | Kenmore 22422 Top Load Washer
Kenmore top load washer won't agitate, but will drain and spin
your dogs may be bad in the agitater.. if u open the lid and turn the agitater back and forth does it rachet or does it turn freely both ways?
Dec 13, 2012 | Kenmore Washing Machines
I have a Kenmore top load washer model 20692. The washer won't drain and whenever the washer is supposed to turn all I hear is a hum. What could be the problem and is it worth fixing in a 10 year old...
Sounds like you have multiple are right... probably not worth fixing...
Look at the front loaders... they use way less water and are more gentile on your clothing...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Aug 08, 2010 | Kenmore Washing Machines
drive coupler, or something stuck in between the tubs. there is a couple of things that can do that
Oct 07, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/
Sep 01, 2009 | Kenmore Washing Machines
Spins slow or not at all, in the spin cycle.
Remove the water pump and check for a blockage in the pump.
If no pump problem replace the brake and the drive coupling.
Feb 22, 2009 | Kenmore 23012 Top Load Washer
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
304 people viewed this question
Top Washing Machines Experts
