Question about Scotts Company Scotts& Accugreeen 2000 Drop Spreader 3 Pack
What model is an accugreen 0730 - Scotts Company Scotts& Accugreeen 2000 Drop Spreader 3 Pack
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I need a replacement part for Scotts 73730 AccuGreen 3000 Deluxe Drop Spreader... the plastic part that holds the cable and threads into the dispensing lever.
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 877-465-5160 at your earliest convenience to check part availability. Hilary @Scotts
Aug 15, 2011 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
Broken plastic opener handle just above micrometer dial
I'm sorry to hear about the problem you are having with your AccuGreen spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 1-800-543-8873 at your earliest convenience to check part availability. Hilary @Scotts
Jul 07, 2011 | Scotts 73730 AccuGreen 3000 Deluxe Drop...
I have a accugreen 1000. The wire for the settings has gone slack and I can't adjust the settings. It just stays open. How do I fix this.
You can try to calibrate the spreader, tightening the screw at the end of the control wire should fix the situation. If calibrating the spreader does not help please call us at 800-543-8873 for more assistance. To Calibrate the Accugreen 1000: 1. Adjust the micrometer setting to a 6. 2. Flip the spreader over. 3. Use your foot to squeeze the trigger against the handle. 4. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. 5. To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insect.
Jun 13, 2011 | RTO Accugreen 1000 Drop Spreader
Wheel has broken off my drop spreader due to corrosion can this be fixed
I'm sorry that the well broke off your AccuGreen 2000 spreader! We do have some parts available for the Accugreen 2000 and I think we can help you with that! Parts are free of charge, just give us a call at 1-800-543-8873 and we can send them out for you! Stacey at Scotts
May 31, 2011 | Scotts Company Scotts& Accugreeen 2000...
Where do I get a part for scotts speedy green spreader? A plastic part broke which controls the fertilizer shut off spout.
Scotts does have some replacement parts available, depending on the SpeedyGreen model you have. Please give Scotts a call at 800-543-8873 and we'll be happy to assist you with replacement parts. Hilary @ Scotts
May 19, 2011 | Scotts Accugreen 3950 Spreader Green 73730
IS there a place that lists spreader settings for the scotts turf builder drop spreader? Are they the same as any of the other more commonly listed spreaders? I want to spread some Lilly Miller Moss Out...
If the product you are planning on applying has a spreader setting for a Scotts AccuGreen, or  specifically for the AccuGreen 3000; you can use that recommendation in your Turf Builder Classic Drop Spreader.  If they do not have a suggested spreader setting for the Accugreen, or  Accugreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Jan 30, 2011 | Scotts Company Scotts Turf Builder Classic...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Feb 15, 2010 | Scotts Company Scotts& Accugreeen 3000...
I want to purchase battery SLB 0730 FOR SAMSUNG
You can get a nice little kit including battery/charger and other accessories here
Mar 15, 2009 | Samsung Cameras
Scotts Company Scotts& Accugreeen 2000 Drop Spreader  3 Pack Logo
144 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
lnbn1975
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
